Heater matrix and bypass valve
Discussion in 'Mk2' started by Eddie Tuke, Jun 16, 2020.
  1. Eddie Tuke Forum Member
    My 16v was recalled back in 90 by VW for a bypass valve to the heater matrix. I'm restoring the car now and having taken the dash out will change the heater matrix as a matter of course. Do I need to put the bypass valve back in? or should I leave it out?
    Grateful, as ever, for any advice, thank you.
  2. Savagesam
    Leave it out :)
  3. Eddie Tuke Forum Member
    Thanks. Is that because the coolant spec has changed, lowering the risk, or something like that?
  4. H8V
    h8v Forum Member
    The original heater matrix was known to sometimes split under pressure and leak "hot coolant" !! over front seat pax legs.
    The pressure reducing bypass valves were VW's fix.
    Later heater cores were better quality.
  5. Eddie Tuke Forum Member
    Fantastic. Thank you.
