Hi Guys. Always read your Threads regarding the GTi. Proud to say I Just Bought my First GTi 2 Days Ago. Its a Stripped Body with lots of Potensial Gonna have a couple of Questions every now & Then. As this will be my First car to rebuild from Scratch on a Tight Budget. Hope to receive a lot of Help & Advise. Till next Time cheers Guys
Thank you for fixing. Why didnt it want to show right? Its going to be an epic project. Got lots of questions. But will post them soon.
It was the wrong link it didn't have jpg in the link I right clicked on the picture and opened in new tab and copied the address
You'll see plenty of these where you are, I'm sure. Mine is the only CITI I have seen in our local area.... Welcome Jon
Yes you right. i had one myself https://imgur.com/a/ZTPaJEV Doesn't look so good anymore Needs her own Grave
Need some advise. what is the correct gap measurement between front fender & Door? I have to start fitting fenders back and tightening but the gap looks too big. Anyone willing to measure and confirm Gap please?
Your using the wrong link If you right click on the pictures and open in new tab used the address from that You will notice it has jpg it must have that to work (IMG]https://i.imgur.com/fdVQj9q_d.jpg?maxwidth=640&shape=thumb&fidelity=medium[/IMG)
Hi Guys. I want the MPG part of my cluster to work. I know that it uses vacuum to determine the mpg. Apparently there are also wires that has to be connected for the mpg to work properly.( im not sure, its what i have read up) Any ideas where the wires connect to? As i will be using a Carburetor Engine not EFI.
Hey Hannes. Just measured mine with a Vernier: drivers side gap is just over 6mm near top and 7mm near bottom of door. Passenger side is just over 5mm all the way, so I guess the correct answer is Who Cares ? I see from your CitiGolf GP plates that you're a Vaalie! I'm an ex Eastern Cape boy myself. Live in UK now - much safer! (Hope you didn't get too bad a whiplash from that sandwich!) Good luck with your project and welcome to the Red Golf Club . Beware the haters haha. Alan
hi guys. need some advise / Help I replaced the whole Wiring loom in Project from Donor Car. I have the following problems. Blower does not work Dash lights do not work Hazard & right Indicator works but left causes the Relay to Shatter. I have only connected the Fender Indicators for testing. No other lights(Globes) are connected. What can I look at as donor car Loom and harness was working. Do i need to reconnect all the Lights(Globes) before i continue testing? Your help is appreciated
Hi there guys. who can tell me where i can get the PCD Changed for my car, currently 4 x 100 want to get it changed to 5 x 100. As the Cr is coming to an end with the Rebuild. I got car with 5 x 100 wheels & Discs, but the Front Stubs & Discs are Damaged. or what would be a perfect fit if i had to buy new Stubs & Discs? Don't want any offset on the wheels. Thank you guys
