help please
Discussion in 'Track Prep & Tech' started by mk2redvr6, Jul 26, 2015.
  1. mk2redvr6 Forum Member
    Hi guys
    Need some advice I have a set of griling g60 twin pots fitted with new yellow stuff pads. 280m disc .Stainless braided hose. a brand new 25.4mm m/c .in rear New mk4 calipers .yellow stuff pads New mk4 stainless hoses and all New 5.1 dot fluid .so the calipers on the front have been totally refub with pistons out and cleaned and New seL kit .so a lot of money spent .now this is a pure track car .and did blyton park last weekend and to tell the truth I wasn't impressed with them I thought there would put me though the window .there didn't.I had to push quite hard to feel them I have bleed these 4 times even took the mk4 calipers off and bleed upside down
    Any advice please
    Cheers
    Lee
  2. Sirguydo
    Bolton
    What size servo you got on ?
  3. MUSHY 16V
    aberdeen
    very little in it between the twin pots and single ones
    i'd look at getting better pads than the ebc yellow stuff pads i'm not a fan of their pads after having a few problems
  4. mk2redvr6 Forum Member
    9 inch servo mate
  5. mk2redvr6 Forum Member
    I used yellow stuff a few times and being happy with them .and at 110 I will wait till there dead
  6. MUSHY 16V
    aberdeen
    I had them come off the backing twice on my old 8v in the mid 90's
    What ever they are bonded with doesn't like a lot of heat
    If that's on my standard road car I'd hate to think how they get on with a track day lol
    Some people swear by them though
  7. mk2redvr6 Forum Member
    Hi chaps
    Could it be that the M/C is two big that's why it's taking more push on the pedel the S2 Audi used a 25.4Mm M/C
    It's just I got croft on the 16th doing a sprint race day and I really feel I need to stop lol
  8. Nige
    Nige Paid Member Paid Member
    That was 20 years ago man !. They`ve improved a lot since then ;)
  9. MUSHY 16V
    aberdeen
    Wouldn't take them if they were free in a lucky bag
    Their discs are OK had a few sets over the years
    You are welcome to test them for me if you like
  10. Finite
    Northamptonshire
    You need to revert to the correct size M/C of 22.2mm. The 25.4mm will just drop the line pressure, increase the volume and lower the clamping force at what were typical pedal pressures. At speed it's difficult to produce sufficient pedal pressure as the volume works against you.
  11. Nige
    I ran Yellowstuff successfully for years. I`ve posted positive things about them many times.
    They aren`t the best pad out there by any means, but they aren`t as bad as they used to be either. For a budget pad, they are good and I had no complaints until I started going quicker. Matt runs them on his 328i and they are excellent, easily bringing in the ABS if you stamp on the pedal. The only downside they`ve never fixed is the somewhat wooden feel.
    What he said. I ran a 22.2 one at first but switched to the 25.4mm one. I needed more pedal pressure for the same brake performance, but found the higher, stiffer pedal made H&T downshifts much easier. Now I`ve gone to better brakes, I`ve switched to a 23.8mm MC as that`s better suited to the brakes and H&T where the 25.4mm one was too big.
  12. MUSHY 16V
    aberdeen
    I found them OK the only problem I had was the pad came off the backing
    This happened twice
    First with the first set and then with the replacement set
    I didn't bother going back a second time
    I just got ferodo pads that I had use before the ebc one
    They lasted till they needed changing without the pad coming off
  13. Peter Jones Forum Member
    Australia
    I had a set of G60s on my race car and wasn't too impressed.
    I ran EBC redstuff pads and just couldn't get the pedal to feel right.
    I suspect the pads were knocking off a bit.
    The G60 calipers are super heavy too.
    All my issues went away when I upgraded to Tarox B280-6 calipers on the same sized discs.
    Pedal feel and stopping power were vastly improved.
