Help/pointers needed
Discussion in 'Mk1' started by Mark duggan, Oct 15, 2019.
Idle help
  1. Help
    100.0%
  2. Help
    0 vote(s)
    0.0%
Multiple votes are allowed.
  1. Mark duggan New Member
    Hi.
    A guy fitted new vacuum pipes & had a clean up of a few parts on my mk1 gti & ever since it races up to around 2k revs on cold then when warm drops down to 1k?
    People tell me it must be vacuum leak, but I can't see it, it was on low revs actually before the new pipes.....
    Any ideas great appreciated
    You'll have to check and make sure he did them all, and properly.
  3. pigbladder Forum Addict
    cambridge , uk
    if its a paid job at a garage then you should return and say its not right
    theres a chance its had a vac leak for years and inexperienced folk have adjusted the engine without seeing it , now its fixed it needs retuning ?
    Mark duggan likes this.
  4. Sirguydo
    Bolton
    my thoughts as well
  5. Mark duggan New Member
    Thanks, good idea , although just fitted a new meter head & still the same disconnected the 5th injector & same
    I'm going to vote for 'help' :lol:
    have a read of this 16v guide:
    https://www.clubgti.com/forums/inde...air-and-tune-your-mk2-corrado-1-8-16v.195423/
    the basic kjet checks all apply to a mk1 as its still the same basic fuel system, just the 16v has a fancy ignition ecu and idle control unit dropped on top.
    For basic timing mark reference use my digifant thread:
    https://clubgti.com/forums/index.ph...ose-and-tune-your-mk2-digifant-gti-8v.124949/
    then for ignition timing it depends if you have a 1.6 or 1.8 engine the method used :)
  7. pigbladder Forum Addict
    cambridge , uk
    dont start guessing at parts , its gets expensive very quickly and replacement parts are often worse than the old german parts
    needs the basic set up going through first , these arent hard to work on but you might might struggle with younger mechanics that have never seen one
  8. Mark duggan New Member
    Thanks for the link rubjonny & all comments.
    Yes indeed, I've had the CSR for over a year & can't find anyone who knows their way around the car! I've been messed around , paid out & as 1 problems fixed it causes 2 more
  9. cerips New Member
    Squirt a small amount of easy start or carb cleaner on the pipes, if the revs pick up you've found your air leak.
  10. Mark duggan New Member
    great idea using easy start to find leaks, but i do not think it has air leaks as fitted & checked new pipes......
  11. Mark duggan New Member
    hi again chaps.
    i cannot find any leaks & as said has new pipes to vacuums . i wonder now if he has put them back in the wrong places!?
    i have 3 small vac pipes: 2 on the inlet , 1 on dizzy 1 on rear of throttle body.......what should go where?????
    thanks again
