Help with Passat APU swap into Rx8
Discussion in '1.8 & 1.8T' started by TopSpeedGarage, Oct 19, 2018.
  1. TopSpeedGarage New Member
    hello friends, sorry for my english i am from grecce
    i swap 20vt apu engine too rx8 and i need some help with loom or conections
    you can contact with me topspeedgarage@yahoo.gr mail
    thank for all
  2. TopSpeedGarage New Member
    hello friends can somebody help me with electrical conections
  3. rubjonny
  4. TopSpeedGarage New Member
    thank you rubjonny byt i need connection from vw passat loom or another 20vt too rx8 loom
  5. rubjonny
    ive a couple passat diagrams as well, 3b2/3b3___ecu.pdf. rx8 loom info might be better looking in mazda forums.
    or at least make a new thread ;)
    copied into a new thread, hopefully this will get more views :thumbup:
  7. rubjonny
    Passat APU, 99-on
    T10b - 10 pin, black
    1 - blu - alternator pin D+
    2 - grn/blu - ecu pin 37 (rev counter signal)
    3 - wht/gry - oil pressure switch
    4 - red - permanent live for ecu & ecu + coilpack power relay
    5 - brn/yel - earth for coolant temperature and level sensors for clocks
    7 - blu/yel - coolant level sensor for clocks
    8 - red/blu - fuel pump relay earth trigger
    9 - blu/brn - coolant temp sensor for clocks
    10 - brn/red - speedometer sender for clocks
    T10d - 10 pin, brown
    1 - grn/blk - diagnostics K-line
    2 - yel/brn - ecu pin 47 (Emissions fault lamp, unused)
    3 - wht/blu - vehicle speed signal
    4 - red/black - starter motor pin 50
    8 - blk/red - oil level temp sensor pin 1 (ignition live)
    9 - blu/gry - oil level/temp sensor pin 3 (sensor feed to clocks)
    10 - yel - ecu pin 81 (mpg signal, unused)
    T10e
    1 - red/grn - power to ecu and coilpacks from supply relay
    2 - red/brn - ecu pin 48 (EPC fault lamp, unused)
    4 - red/grn - ignition live (10a fuse)
    5 - grn/yel - power to injectors (fuel pump relay, 20a fuse)
    6 - wht/yel - ecu pin 80 (fuel system diagnostic pump, unused)
    8 - grn/yel - power for engine control valves (from fuel relay, 15a fuse)
    T15a - 15 pin, white
    1 - yel/blu - DBW pedal pin 4 (T6r black plug pin 1)
    2 - yel/pur - DBW pedal pin 2 (T6r black plug pin 2)
    3 - brn/red - DBW pedal pin 3 (T6r black plug pin 3)
    4 - gry/yel - DBW pedal pin 5 (T6r black plug pin 4)
    5 - gry - DBW pedal pin 1 (T6r black plug pin 5)
    6 - brn/grn - DBW pedal pin 6 (T6r black plug pin 6)
    7 - red/gry - cruise control
    8 - blu - cruise control
    9 - red/yel - cruise control
    10 - blk/wht - cruise control
    11 - red/black - brake light switch pin 2 (brakes on)
    12 - wht/red - brake light switch pin 4 (cruise control brake switch)
    13 - red/grn - clutch switch
    T15s - 15 pin, red
    1 - grn/brn - ABS unit (only for models with TCS)
    2 - blk/yel - speed boost signal (aircon/heated screen switch)
    3 - blk/gry - aircon
    5 - blk/pur - ecu pin 30 (unused)
    14 - org/brn - CAN-BUS LOW
    15 - org/blk - CAN-BUS HIGH
  8. TopSpeedGarage New Member
    rubjonny thank you for list
    maybe yoy have a conections with rx8 loom
  9. rubjonny
    unfortunately I have no data for the RX8 looms, if you have a wiring diagram to hand I can try and reverse engineer it for you
  10. TopSpeedGarage New Member
    rubjonny i dont have rx8 loom data
    maybe you have ecu pinouts from apu engine
  11. rubjonny
    have a look in my signature link for the VW wiring diagrams, plus I've listed all the pins on the ecu loom plugs to fusebox you need to splice up in my post above, should do you on the APU side. just need to find RX8 wiring diagrams
  12. TopSpeedGarage New Member
    thank you for all rudjonny
