Home made Roll cage steel question
Discussion in 'Track Prep & Tech' started by 10mm socket, Sep 19, 2017.
  1. 10mm socket Paid Member Paid Member
    Morning guys and gals,
    I'm considering building my own roll cage to msa /fia regs. I see the minimum steel type they req is cold drawn steel with a minimum strength yield of 350 N/mm2, I can get some quality cold formed steel tube s355 grade with a yield of 355 N/mm2.... a high strength constructional / mechanical tubing.
    I see it like this, they are asking for strength and this cfs is stronger than there minimum standard.
    Please discuss
  2. Jon Olds Forum Junkie
    I would be looking at the MSA regs aka the 'blue book'
    Jon
  3. 10mm socket Paid Member Paid Member
    Thanks Jon, I have. That's where the reference has come from
  4. Nige
    Nige Paid Member Paid Member
    The dimensions are also critical, it`s not just the strength. The Blue Book specifies tube OD and thicknesses, if you go away from that you aren`t complying. If you aren`t competing the question is, does it really matter ?
    But for the minimal price difference I always buy the CDS tube in the dimensions specified by the MSA
    10mm socket and Sirguydo like this.
  5. Sirguydo
    Bolton
    Nige do you have a spare 1200mm piece knocking about as I'd like to weld a harness bar in mine ?
  6. 10mm socket Paid Member Paid Member
    What an odd question or statement.....however you meant. If I'm interested in building a complying roll cage, it's probably because I'm interested in competing in a msa/ fia ruled sport.
  7. Nige
    I was meaning that if the tube is strong enough and above the specs, the o/d and i/d isn`t an issue if it`s oversized.
    eg, if the tube should be 44.45mm x 2.64mm but your supplier has 45mm x 2.75mm then that would be suitable but not listed in the Blue Book. Make sense ?
    10mm socket likes this.
  8. 10mm socket Paid Member Paid Member
    Perfectly clear.... thanks.
    Nige likes this.
  9. 10mm socket Paid Member Paid Member
    Do all cage pieces have to made of 45mm or is it just the main cube sides, then braces be 38mm
  10. Nige
    The Mandatory pieces can be 45mm x 2.5mm or 50mm x2 mm
    Optional can be 38mm x 2.5mm or 40mm x 2mm
    More details and diagrams in the Blue Book Section K
  11. 10mm socket Paid Member Paid Member
    Thanks nige, what are the mandatory items..I can't then listed.
    Oh, I've just found a stockist of reasonably priced cds tube, but they're out of stock for another 4 weeks
  12. notenoughtime
    Essex
    You need 1200mm? 45mm or 38mm
    45mm x 2.75mm main hoops and 38mm x 2.5mm
    I can order it 4-5 days
