How to ...Fitting Focus/Seat Short master cylinder to mk2 servo modification for 1.8t
Discussion in 'Chassis' started by fasteddie, Sep 5, 2014.
  1. rubjonny
    The main reason you fit them is to give you more space for the 20v engine, since its larger round the back of the cylinder head.
    Pigbladder on here fitted one to his G60 with 280mm brakes and took it off again as he didnt like the feel of it vs a well bled 22mm. So YMMV
    Y M M V....
    Your mileage may vary?
    Your method may vary?
    You make me vomit?
    C'mon RJ, You have me perplexed now :p
    Savagesam likes this.
  3. GVK
    Your mileage may vary - means the advice you get on the internet may vary with your own findings. :)
  4. Tristan
    Ah-ha.
  5. rubjonny
    Yellow Monkeys Mime Victoriously
  6. BRI
    bri Forum Member
    Ireland
    Ok so no real benefit in terms of increased fluid displacement vs pedal travel ?
    I read that a T4 Transporter 25.4mm m/c might work in my case so I'll check that out.
  7. rubjonny
    they do move a little more fluid, but as I say you may not like the change. personal preference. Id say unless you have a 20v engine its not worth the added hassle, you can get 24mm direct fit units if you need something that pushes more fluid for a normal engine
    bri likes this.
  8. BRI
    bri Forum Member
    Ireland
    What suitable 24mm m/c is there available ?
  9. rubjonny
    Try 6N0614019A, some MK3 and polo 23.81mm :)
  10. Tristan
    Those pesky yellow monkeys... [:D]
    Isn't there a Transporter cylinder too that fits?
    Have you a long pedal on the G, Brian?
  11. rubjonny
    yep sure is, bit overkill for most applications 7D0611019A
  12. BRI
    bri Forum Member
    Ireland
    Hi thanks for that,
    Most searches using that part number bring up a 22.2 mm master cylinder though?
  13. BRI
    bri Forum Member
    Ireland
    I belive a t4 transporter 25.4mm m/c will work alright but it might be too much the other way??
    Seat used a 23mm m/c on the ibiza that my calipers are lifted from ..
    Yeah the g60 T , I've beld the bejasus out of them and it still quite long I think , might try again though with the old two person pedal method, there was a lot of air in the rears .
  14. Neil_Ireland Forum Member
    I’m in the same situation, I never thought the pedal feel inspired confidence, it always felt long. G60 fitted to mine.
    Interested in this 6N0614019A, does it take the same size brake line fittings?
  15. Tristan
    I presume you had the calipers off and hanging up as far as the flexi allows, nipple pointing up?
  16. Tristan
    I thought yours wasn't bad when I drove it, though that's years ago.
    Have you adjusted the handbrake lately, by cranking out the lever on the calipers?
    I find adjusting them up there, rather than tightening the cable gives a better brake. And uou always get another crank out of them with the caliper off, i like to have them just snugly sliding on over the pads.
  17. rubjonny
    'most searches' are wrong then :p
    as its ABS type the fittings are M12, seems lots of the searches mistakenly list 6N0614019A as being the same as 6N0614019
  18. Neil_Ireland Forum Member
    The car has no brakes on it now, I’ve bought new calipers, discs and pads to refresh everything.
    The pedal travel always felt long to me compared to modern stuff, it just never felt right imo.
    Is there anything available with m10 fittings, same as original mk2?
  19. rubjonny
    bri and Neil_Ireland like this.
  20. dodgy
