Ht rotor arm stuck damage?.
Discussion in '8-valve' started by mrglee, May 18, 2019.
  1. mrglee Forum Member
    Got a full set of leads cap and arm but can't get the old rotor arm off when I pull the arm the shaft moves with it a little then stops but don't know if I'm going to damage something by getting forceful with it.
    They can get tight. If you have a new one , you could butcher the old one so, by slitting it.
  3. mrglee Forum Member
    Ok thanks took the dizzy out in the end and put the rotor arm in a vice bit of pulling and wobbling and she's off.
  4. pigbladder Forum Addict
    cambridge , uk
    crush with pliers is the official way
  5. GVK
    Some are glued on ;)
