Indicator problem
Discussion in 'Mk1' started by 0337, Oct 12, 2019.
  1. 0337 Paid Member Paid Member
    Hi all, I have a H reg golf cabriolet GTI, it has started playing up with the indicators. When I put in left or right indicators on they are not flashing, but if I push the hazard switch half way they work. Hazard work no problem. I did get a new hazard light switch and installed that but still the same. All the wires are installed like the small wire and 1 large spade they wire too, think it was a brown one. Any advise is much appreciated and thanks again.
    check fuse 19 :)
  3. 0337 Paid Member Paid Member
    Hi Rubjonny, spot on again, it was fuse 19. I would have thought that relays are put in place for them to work as they should not fuses.
  4. 0337 Paid Member Paid Member
    Thanks very much, where would we be with out all your help and knowledge.
  5. rubjonny
    there is an indicator relay yep, the fuse is just there to protect the ignition live wire to the hazard switch from damage if anything shorts out :)
