Is my engine 1.1l or 1.3?
Discussion in '8-valve' started by sambo, Apr 14, 2005.
  1. sambo Paid Member Paid Member
    Checked engine num and it is original however in logbook its printed engine code GC which must be a typo as the code is GG. Mighty 1.1 it is :lol: It should do fine for my g-friend as a first car tho
    Haynes lists:
    1.1 litre 1980-on models:
    Engine nos first (range I assume):
    GG 000 001: 31 PIC-6
    GG 800 001 (Formel E): 31 PIC-6
    GG 799 999: 31 PIC-7
    GG 800 0000: 31 PIC-7
    Sounds like all should make sense.
  3. sambo Paid Member Paid Member
    Am i right to think these carbs can be tempermental? If so and i need to replace it, is webber best option? Where is the best place to get one? thanks
  4. OSV
    OSV Forum Member
    We serviced the Carb on the Polo Sam with a full service kit together with a clean out.Its the same mighty engine as yours, runs nice now, but with a far superior power/weight ratio it will blow your doors off. :lol:
  5. sambo Paid Member Paid Member
    :lol: Garreth,if what you do for living was different i would chalenge you to a race on the way to a next show! ;) :lol:
  6. mk1 driver Forum Junkie
    Nottingham
    I will have a Weber replacement carb avaliable soon off my Driver (Kit No. 15290992 (1.3) 1977-1983) it replaces the Solex 31 PIC - 6/7.
    Hardly covered any distance, less than 400 miles.
  7. sambo Paid Member Paid Member
    Will your weber fit my 1.1l engine? If so how much do you want for it?
  8. mk1 driver Forum Junkie
    Nottingham
    Well, Kit No. 15290991 is for a 1.1 and it says the same thing, replaces the Solex 31 PIC - 6/7.
    Another difference from a 1.1 and 1.3 I can think of is the pipe which comes off the downpipe and upto the underside of the inlet manifold to warm the fuel/air mix. Also I dont think the 1.1's had a corregated pipe just prior to the centre box and after the downpipe/system connection?
    I also have a new 'Ernst' downpipe with that bit I've just mentioned above in it.
    Quite a few other bits as well that I dont need that have covered the same mileage as the carb just about, leads, plugs (i think), clutch, thermostat, thermoswitch....
    Anyhow's, e-mail me if you want anything. :)
