Jenvey DTH Throttle Bodies
Discussion in 'Throttle bodies & non-OEM ECUs' started by Neal H, Aug 29, 2008.
  1. badger5
    nr Glos
    DTA is programmable by yourself tho dude.. ;)
  2. badger5
    nr Glos
    nice to see the Jenvey DTH bodies flow well in their 45mm guise.
    they were originally cast to be 48mm and up, but when I got involved with them & Jenvey to help finish their development and testing (my old Jetta ran the prototypes) I thought for majority of 16v users, 45mm was more than enough for what the 16v vw head can actually flow. (not being a very good head relative to the same era red tops)
    Woudl love to see what rebuilding Robts into 48mm would do on an engine which justifies that little extra .
    rock & roll
  3. Neal H Forum Member
    Me too, go on Rob, you know it makes sense... ;) :thumbup:
  4. RobT
    RobT Forum Junkie
    Cheshire
    when I get my new snick-snick gearbox I may well do this - will be able to get away with a more revvy engine if the gears will take it - have not done this so far as the synchros just wont take any more abuse, marginal as it is
    I know for a fact that 48's on a longer DCOE-type manifold will give another 12-15hp on my engine. I dont think the DTH's will give up this much as the injector is much closer to the head but maybe another 10hp with better throttle response than a far away injector
    8-injectors is obviously the way to go but thats would need a new ECU etc etc etc and I have better things to spend my dough on right now
  5. aj_gti Forum Member
    Just picked up a pair of 48 jenveys for my next project.
    Quality of the machined finish in the bores is shocking!
    Looks more like a fine thread than a turned surface, and you can see light all around the butterfly even when it's fully closed. Seems they don't need to be so 'finely' finshed as a carb afterall.
  6. RobT
    RobT Forum Junkie
    Cheshire
    thats poor - my 45 dth's are very smooth, just as they should be - there should be no light through the butterfly - I would send em back
  7. s1m0n Forum Member
    Northants
    I have SFE's (4 x individual bodies) and the internal machining is excellent.
    Sound like they "escaped" a machining process, send em back!
    Cheers
    Simon
  8. Brookster
    M1 J40
    Mine arrived the other day !! :)
    DTH Jenvey 45's from Bill.
  9. badger5
    nr Glos
    Reject them. That is not acceptable
  10. aj_gti Forum Member
    ANyone got a close up pic(using macro) of the bore on their Jenveys? Maybe I'm being a little picky for not having a super smooth bore, while thinking my turned finish isn't good enough.
  11. Neal H Forum Member
    I might have some, I will take a look tomorrow
  12. Brookster
    M1 J40
    My new ones are polishied fron the trumpet to the butterfly, then after the butterfly to the head not a polished finish.
    as you can see on this pic.
  13. badger5
    nr Glos
    the butterfly fit described is what i would reject them for
  14. Neal H Forum Member
    I have some more pictures that may help. The area around the butterfly is a turned finish as you mention above - fairly smooth, probably equivalent to 60 grit paper I guess. The transition from round to oval is an "as cast" finish.
    Some pics
  15. Neal H Forum Member
    And one more
  16. badger5
    nr Glos
    I think the comparison is DCOE style bodies to DTH, where DCOE bodies are turned the whole length
  17. Brookster
    M1 J40
    Bill
    have you got any detailed picture showing the DTH's fitted to the Head, i want to look at the throttle cable details. :thumbup:
  18. badger5
    nr Glos
    http://www.badger-5.com/bin/throttle-cable-instructions.pdf
    here is a picture of the install.
    regards
    bill
  19. Brookster
    M1 J40
    Cheers Badger
  20. J0HN30Y Forum Member
    Woking
    Great thread guys, learnt more reading this then 1.5 years on a Auto engineering foundation degree! It's awesome how u guys share info, one day hopefully i'll have more to add!
    I wish i'd paid more attention to the details when my head was done about 6 years ago. Also a lot of whats described here goes against what I was taught on a work experience placement where we worked on an 8v head - unless crossflow heads work on a different principal?
    I've dreamt of throttle bodies for 9 years :)
