Jetta Mk2 1.6 automatic gearbox change
Discussion in 'Transmission' started by trubang, Sep 18, 2020.
  1. trubang New Member
    Hello guys, I'm driving mk2 jetta 3 speed automatic and I have to change the gearbox. My question is did anybody know, if a 4 speed automatic gearbox from golf mk3/ibiza 6k will fit?
    yeah mk3 golf one will go, ibiza up to 2001 is also same front running gear so that would also fit.as long as its not an ecu controlled one you will be ok, as those require ECU inputs to work. main one is throttle position, unless theres a way around it. automatics not my stron suit
    trubang likes this.
  3. trubang New Member
    Thanks. The problem is that I don't if there are any without ecu on the mk3 golf.
