Hi bill. Have you got a price on a Ko3s hybrid please?? My engine is in the process of a rebuild so i figured now's the ideal time! Cheers in advance!
ex vat inc vat Silicon TIP 114.45 131.62 FMA45-80, 80mm 45' bend 19.00 21.85 FMHJ76 - 76mm ally joiner 7.34 8.44 CRT04-k04 hybrid k03fitment turbo 505.00 580.75 ** CRT04-k04 hybrid k03fitment turbo 675.00 776.25 *** hi-flow ex manifold 299.00 343.85 * stage 3 mapping 550.00 632.50 LCR MAF 85.00 97.75 LCR Injectors 270.00 310.50 LCR Fuel pump 160.00 184.00 * 80mm 200mm Green Filter 47.00 54.05 fitting turbo 380.00 437.00 fitting big bore manifold 75.00 86.25 **** * Optional ** Presumes Core unit is servicable and not cracked else *** applies *** Non-Exchange **** If fitting big bore manifold supplied and it takes longer contingency Hoses for brembo fitment (boxter-s rears) yes, same hose I do for regular brembo's 47.50/pair +vat and postage
spot on Bill, i'll have a dig through what i already have on that list and get back to you shortly! i'll defo be having a set of flexys too Catch you shortly (those prices all + VAT by the way??)
Hi Bill, i am currently in the process of collecting parts for a hybrid setup, however will i be able to run the car in order to get it to yours to be mapped. Or is that a no go on starting it until its with you. cheers.
