Lupo GTI box to replace troublesome 020
Discussion in 'Transmission' started by copeidge, Aug 21, 2020.
  1. copeidge
    copeidge Forum Member
    Hi guys, I'm on my 2nd 020 box, the original one got stuck in 3rd on track. Last weekend my 2nd 020 also got stuck in 3rd but I managed to free it and its been fine since.
    Speaking to Martin at Gas n Gears he recons its a bad design on the 3rd gear hub, where the keys drop out.
    Hes sounded confident that a full box rebuild would sort out the issue.
    a full build is looking around the £700 plus getting my box to and from martins unit.
    That being said I've been looking at alternatives, in particular 02a and 02j boxes.
    I'm happy to do the conversion and sort out the hydro pedal box etc.
    It just dawned on me after going out in a mates lupo gti that the box is 6 speed and the ratios are lovely and short, which is ideal for my 8v. Any longer ratios and it would serious kill the little power it already has!
    So a simple questions is.. has anyone every fit a lupo gti 6speed into a mk2?
    is it doable? I cant find any info online so I'm assuming it cant be done.
    But any info/advice would be helpful!
    Cheers :)
  2. GVK
    I don't think the bellhousing of the Lupo 'box suits/fits the 'big block' mk2 engine.
    I broke a few 3rd gear syncro on my 020s too.
  3. copeidge
    I thought that might be the case but i though i might be able to use the bell housing from an 02A.?
  4. Tristan
    I looked into this too, and it seemed the Lupo box isn't very strong.
    I fitted an 02j, with a tdi Shifter. Another option is the 02s which is like an 02a/j with an extra gear.
  5. Savagesam
    And you still have to fit it into an 02j box because the 02s doesn’t have the correct holes in the bell housing
  6. Tristan
    You can just use the bell housing.
  7. dodgy
    Cant remember where I read it, or if correct, but do polo 9n3 gearbox from tdi have bellhousing that had bolt holes for small and big block?
    Sure I saw the bluemotion one fitted to 1.8?
    Might be completely wrong, but may be worth investigating.
  8. Hotgolf
    Smelly Cornelly
    Use a late 020/K 3rd/4th hub and it'll eliminate the issue for good. Early 020 hub/sleeve/key design is awful. The polo 02t boxes are properly weak!!!
  9. drunkenalan Paid Member Paid Member
    Leicester
    I have had a similar issue in mine, some spirited driving in the lanes, mostly 3rd gear, went for 4th and I couldn't move it!, let it all cool down whilst nursing it on the way home and it came free, only happened twice to me but generally the box is OK, pretty sure its been rebuilt at some point
  10. Hotgolf
    Smelly Cornelly
    Early hubs are shite. If you lose the keys you ‘could’ end up losing the whole box.
