Megasquirt Newbie Questions - All the really dumb ones you were afraid to ask!
Discussion in 'Throttle bodies & non-OEM ECUs' started by Mike_H, Apr 27, 2010.
  1. Toyotec
    Your board if it is a version 3 PCB will be as the picture. Green is a version 2.2 PCB.
    I should have the NTC values for the VW "027" sensors but not with me at the moment.
    Sounds like the 'cold temp' resistance is wrong.
  2. brutalmk2-16v Forum Member
    Manchester
    Ok i found my receipt to be sure and the PCB version is 3.57
    Would you be so kind to post them later on when you have time?
  3. Toyotec
    Ah that would be SMD.
  4. brutalmk2-16v Forum Member
    Manchester
    SMD ??
  5. tshirt2k
    tshirt2k Forum Junkie
    Herts
    Surface Mount
  6. brutalmk2-16v Forum Member
    Manchester
    explanation? :p
  7. tshirt2k
    Herts
    Surely you can use Google? Its pre built using small surface mount components. You may not have the usual type resistors with bands but you will have a code instead.
  8. brutalmk2-16v Forum Member
    Manchester
    How can i use google if i didn't even understand about what he was talking about? I can't guess. And btw google gives surface mount as SMT and not SMD. Thanks anyway..
  9. tshirt2k
    Herts
    Same thing.
  10. emery1990 Forum Member
    This question may be thick :) I've always used super unleaded, just wandering as it's now probably 4 months old will the spark not be able to advance as much as if the fuel was fresh, or will it be the same as fresh super unleaded.
    As don't want to finish mapping it then find out it was detonating earlier.
  11. tshirt2k
    Herts
    Whats the problem then? Not all super unleadeds are the same. I remember having a problem with BP ultimate
  12. emery1990 Forum Member
    No problem atm, was just wandering whether before mapping I should fresh super in it. As maybe it breaks down and the octane rating falls? Yer my 1.8t never use to respond aswell with bp ultimate. I've got v-power in there atm. Think about 30 litres, could sell it on for a profit with prices atm !
    I've been quite atm as was sorting my brakes out before starting to map it! There being a pain in the ****... But this weekend I'm ready to start getting started on it.
  13. Toyotec
    Put fresh super in it. Else just calibrate for RON95.
  14. emery1990 Forum Member
    Ok I'll get some new fuel then rather than tweaking it at a later date.
  15. tshirt2k
    Herts
    You may aswell start mapping with the fuel in it. I'm sure it will be a while until you start WOT high load mapping anyway. Startup/warmup can tend to use some fuel until you get it fine tuned.
  16. emery1990 Forum Member
    OK is that because under light load if I here DET I can stop but under high load it happens much faster and may do damage before I can stop.
    Yer doubt will be this month, depends how fast I get my head around it!.
  17. tshirt2k
    Herts
    The base map should be a "safe" one anyway. You'll be surprised how much fuel you can use even when mapping cruise and idle areas. Or just make sure light load areas are mapped on that fuel if you are worried. Better than wasting it.
  18. mk2abf Forum Member
    edinburgh
    question from me ;)
    how hard would it be to map itbs on speed density ?
    i am running my mk2 abf on ms2v3 fully mapped seeing 15-16 on cruise and around 12.7 wot
    i know i am going to tune the whole ve table again but how much of a pita will it be trying to map itbs on s/d ?
    never even looked at alpha before !
  19. hasoooon93 Forum Member
    hello guys.... this is my first post here so hello for all members
    my question is : i have vw golf mk1 16v pl engine ... so i would like to have efi .. what is megasquirt i must put it to my engine .... and what kind injector i must put it ....
  20. brutalmk2-16v Forum Member
    Manchester
    Toyo any update on this?
