MK1 ABF shopping list
Discussion in 'Badger5' started by DGT, Jul 21, 2009.
  1. DGT
    DGT Forum Member
    The Highlands
    Ive got a mk1 clipper cab ive uprated the fuel system,brakes,suspension etc and im almost ready to start fitting the ABF motor.
    id like to run the DTH bodies, could you give me a rundown of the parts ill need.
    i have a modified ABF ECU with modified mk1 loom, i will be using the existing crank sensor and most likely ford edis (or possibly a modified dizzy cap from a pug)
    i have a 1.8T fuel rail if thats any use?
    any advice would be greatly appreciated
  2. micky1 Forum Member
    Bath.
    Dunno mate but i say that a KR 16v on k jet goes ok in a cab!
  3. badger5
    nr Glos
    so you are saying you have management system sorted by your proposed abf ecu and edis etc...
    bodies themselves are - 549/pair
    fuel rail - 48
    Throttle mechanism to use std VW cable - 98
    airhorns 45x120 - 27.60/each
    throttle pot - 49.90
    throttle pot electrical connector - 10.56
    Above prices are exv vat, but I can offer 15% discount so effectively these are inc vat prices if that makes sense.
    delivery is 12
    regards
  4. altern8 Forum Junkie
    Cocos (Keeling) Islands
    Out of intrest does the abf have a trigger wheel too?
  5. DGT
    DGT Forum Member
    The Highlands
    sorry,bit of a last minute of lunchtime post there
    yes i have managment sorted..thanks for the prices:)
  6. badger5
    nr Glos
    yes... but usually a hall sender not reluctor sender so you need to swap that out for most aftermarket ecu's
