Hi. I'm close to finishing my engine conversion on my mk1 caddy and need some help to get it finally running. Started as a 1.6 d ce1. The spec now is: 1.8l 16v kr Ce1 caddy loom conversion with a mk2 golf ce2 loom by custom tweaks Mk2 golf clocks (8000 remember counter single plug) Ce1 caddy fuse box Mk2 golf ecu. First issue is that the Metering head doesn't seem to have the outlets for the WUR valve, is this a issue? Can I run it without? Also the wiring loom that I had done doesn't seem to have the plug connectors for the throttle switch (3 pin) and there doesn't seem to be a plug for the idle control valve. Am I missing something? There is a few other issues they can wait. Any help is much appreciated
