mk1 golf 1.1c, now with added ALT 2.0 20v on 48's!
Discussion in 'Members Gallery' started by seventynine, Sep 13, 2013.
  1. 51ngh Forum Member
    London
    Bloomin Keyboards! some very good work there! :clap:
  2. seventynine Forum Member
    Wales/Essex
    So let me start by saying this is the first manifold i've made so go easy on the fit/welding/whatever
    i started by making a pair of jigs for cutting, one was essentially for mitre'ing straight lengths for the collector, the other was for cutting both round and bent pipe into correct lengths and angles
    now with the merge collector there's a bit of maths involved to work out the rotation angle in order to get a perfect fit, if the pipes were parrelel and on a 4 cylinder engine this would be 90 degrees, but as you increase the merge angle the angle of turn increases in a sinisoidal manner, i did a bit of trig and knocked up a simple spreadsheet
    with this new found knowledge i cut the second angle in the collector
    when i offered it up back on the car i realised there was no way a 35 degree merge angle would work lol back to the drawing board
    8 degree merge angle fitted in the bay much easier!
    v[​IMG]
    welded it all together, and cut flat
    then welded the V band
    with that out the way i had to redesign the manifold again to account for the different merge angle, there is definitely a correct order to do these things in, and the order i did was not it haha,
    the second jig -
    all cut -
    in the ICEngineworks kit they also supplied tack clamps, for mocking up the steel sections, they came in *so* useful
    bit of fiddling and a few hours later the whole thing was tacked and looking something that you'd recognise as a car part
    excuse some of the fit up on the collector, turns out that bit was quite tricky!
    apart it all come for welding, got some pipe stoppers used for stopping leaks in plumbing circles, which i adapted to fit onto a gas feed, having only one regulator i used that to work out the flow on both gas outputs, which didn't really work and i wasted a lot of gas, like a lot, i've since got a second regulator lol
    welded up and tacked to the flange, wasn't the greatest fit to the merge collecter but it's nothing i can't bridge
    welded to the collector
    unfortunately i've had to hide all my handiwork under some heat wrap as anyone who knows mk1's will know how close the steering knuckle and driveshaft are back there
    next stop, wiring :)
    HPR, 1990, Toyotec and 1 other person like this.
  3. liamrus New Member
    Amazing work buddy great attempt for a first time.
  4. seventynine Forum Member
    Wales/Essex
    and this is it fitted btw
  5. Sirguydo
    Bolton
    Top notch mate :thumbup:
    Very nice work keep the updates coming :thumbup:
  6. seventynine Forum Member
    Wales/Essex
    entered the trackday fold too, with the daily parts hauler
    which did nothing but highlight how many bushes need replacing lol
  7. havenhand New Member
    Wow, that exhaust manifold is the nuts! So much awesome work in this build
  8. bbs_rs New Member
    Stunning exhaust manifold.
    Which camshafts do you have in mind?
  9. Tristan
    Great work! Did you make a template?
  10. 1990
    1990 Paid Member Paid Member
    Rochdale, Lancs
    Those photos and your work are amazing!!!!!
  11. Brookster
    M1 J40
    nice work
  12. seventynine Forum Member
    Wales/Essex
    I hear there will be some available very soon for the NA 20v from a UK supplier. not sure on details yet but i know of another tuner building up a well specced NA 20v!
    obviously i'm pretty limited as it's not a common engine useage, worst comes to worst i will get my own profiles ground :)
    long way off that just yet. think for this year i'll get it running with stock internals, then pull it apart when the shell is off for paint early next year
  13. fasteddie
    fasteddie Banned
    That Manifold is Awesome [8D]
  14. coullstar Forum Member
    Scotland
    Impressive work.
  15. 12valver Forum Member
    Very impressive work. The RS4 looks great as well.
  16. seventynine Forum Member
    Wales/Essex
    been busy with a few bits lately, nothing too hands on. planning the wiring loom mainly and designing these -
    got a friend printing them up with his 3D printer this week, then i'll get them wrapped in kevlar to give them a bit of strength. basically will utilise all the leftover frontal area i have
    Toyotec likes this.
  17. Top Fuel New Member
    Don't think i'd ever seen the RS4 engine fetching photo before. Haha
  18. seventynine Forum Member
    Wales/Essex
    Trumpets are currently being printed, 40 hours total time to make the 4 haha
    had a weekend fabbing up a couple of bits i needed, saturday i made a water inlet and outlet -
    and a gearbox mount
    Toyotec likes this.
  19. Tristan
    nice work , that's one of the tidier mounts I've seen made up .
  20. vwgolfmk1 Forum Member
    IRELAND
    Keep up the good work mate, gonna be sweet when finished.
