it sounds worse than it is, you would really have to see the way they fit together yourself. mine has been on there for nearly a year now without a problem do you have bluebird pas in your car? im just curious if you have more steering lock in one direction than the other? i notice the nissan rack is a lot wider than a mk1 rack and it seems like it would have to be mounted more to one side to get the pinion in the right place
I am doing a Corsa conversion at present in my Scirocco, but I know that Richard [crazyquiff@yahoo.com] is doing a bolt in kit in the next few weeks, he is testing one in his Mk1 at the moment. Hope this is of use. Regards Dave Luben
Yes, it is offset to the passenger side, so technically has more lock one side to the other. This is then corrected with an arm extender, which I think achieves a reasonable result (more details on the link). What it does do is create a bump steer difference from side to side. However, given it has been used in the Reeves Golf - a devastating Mk1 track car - for 10 years, I am reasonanbly confident it actually works fairly well. The Reeves would have binned it years ago if it was worthless, and the only reason they changed it was because of the Quaife quick rack group buy we did here on the forum, which enabled a Corsa EPAS variable system to be added, using a manual quick rack, the standard rack ratio being no good.
are you going to gti international and are you taking your mk1? ill have mine there again this year if anyone is interested in looking at the power steering conversion in it you are more than welcome
yes im using a cablechange box so im not worried about the rodshift gearlinkage, now that you point it out it does look like a problem
spotted this on a aussie forum and a couple users from here mazda 323 rack ?http://www.vwwatercooled.org.au/newforum/upload/showthread.php?t=2623 had a quick search for the other post mentioned but could not find it
look at the link again, a guy in australia has fitted the toyota rack and made a bracket to mount the rodshift
I've now done this conversion and I can say it works and very well. After having gone to all the trouble of making brackets for a renault clio rack using it for a month and finding it's crap I came accross this thread and decided to do it. I got a stalet rack off ebay plus the pipes, res, and bottom UJ for about 70 then found a oridginal shape corrola and took the top UJ and splinned bar off the steering colume 15. then got the pipe from a mk4 golf that goes from the resoviour to the return of the pump. as this pipe doubbles back on it's self and is factory formed for easy. Now the hard bits: I'm not a metal working engineer just a central heating engineer so i went to a local farm and had a chat to a sheet metal engineer that was renting a barn who said he'd help me out. Now I've done things slightly different from 666zfj or rownan. I decided that I wanted to keep the horse shoe clamps that go round the rack in one oridginal piece without cutting them up. So to get the steering rack to point towards the hole in the bulk head we got a 5mm steel strip and created a kind of v shape that we drilled holes in to fit to the bulk head, 13mm studs were pressed in to the V, to mount the horse shoe clamps and then we braced the V with extra material for strength. similar to what 666zfj's done at the start of the thread. As for the cut and shut UJ: The engineer i was working with assured me that: "an inch of weld will hold over a tone of weight. so it is more than enough". The corrola top UJ has a welded on sleave that a splinned bar pushes into. So it's welded any way. the top UJ section from the corrola was cut away from the welded on sleave section. (You only want the sleave. chuck the UJ) The sleave was then welded on to a vw UJ. The corrolar splinned bar (which conects the upper and lower UJs) was constantly offered up to the car and slowly cut down to the right size and welded into the the half toyota sleave half vw uj. Now you have a two piece detachable UJ section that connects the colume to the rack. The pressure pipe: keep the pressure pipe from the toyota it does fit as 666zft says, but i found to make it fit better i cut off the banjo fitting from the toyoata pipe, then took the renault clio pressure pipe connection which has a 90degree bend and a fitting that fits all the VW power steering pumps (easy to cut off from a breakers, I already had mine from previous powersteering attempt). and welded the two pipes together. finally a trip to the local motor shop for some rubber hose, a pipe connector, some jubalie clips power steering fluid Oh and a last bit of fabrication for the bracket to hold the resovoiur to the driverside suspension turret and your done. I'll try and do pictures at some point as I know it maybe a confusing read, but it's abit hard as they are on the car. Conclusion: you don't need to be an engineer, get some help and get stuck in. I don't want to take anything away from 666zft, if it weren't for him I'd still have french bit of rubbish on my car so thanks. Both ways work but you don't need to do it the same as us. The rack works brilliant the same lock side to side no play in the mounts or UJ which is the most important thing for safety and driving feel!!! and the whole lot cost about 300 quid and a week of time to do it wasn't easy and i had the luxary of a mock up car and a mate with a proper garage ramp but I'm sure it's all doable without.
hi i also have power steering in my mk1 but with part no R4 53A00 did some searching but not much luck but came across a rack very simuler to what i have the rack is a nissan figaro but i dont know if that has the same part no will keep serching
LHD power steering!! HI Guys, I have a lhd mk1 jetta that needs power steering. Any ideas which way i should go about sourcing parts or can i buy something of the shelf for it?? Thanks
Try eBay France/Germany etc or a Euro auto factors. I doubt you will get a new rack, but a recon rack is entirely possible.
Whilst this other conversation is related to brake parts being different on South African Mk1s, I recently read in VW Driver that later SA Mk1s had power steeering News to me - I'd heard of enquiries to SA previously yielding nothing. Would be a perfect OEM upgrade.
conversion brackets to add power steering from an ep90 Toyota starlet on ebay http://www.ebay.co.uk/itm/300600807985?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1438.l2649 pic of the rack fitted pic of modded uj
Anyone looked at a lhd 944 rack do the job as they came powered http://www.ebay.de/itm/LENKGETRIEBE-SERVOLENKUNG-LENKUNG-PORSCHE-924-944-968-CABRIOLET-/380384774028?pt=DE_Autoteile&fits=Make%3APorsche%7CModel%3A944&hash=item5890b3078c
