mk1 rain tray removal
Discussion in 'Chassis' started by RyanMac, Aug 31, 2010.
  1. RyanMac Forum Member
    I am thinking about moving the metal that seperates the engine bay from the raintray but just want to know how big a job this is and how would I go about it....Is it just a case of cutting out the metal and rewelding the seam? what happens with the vin number?
    Thanks
  2. MK1-Tron
    MK1-Tron Forum Member
    Staffordshire
    Its not a big job to get it out, and no need to re-weld the seam, the rain tray section you remove is a seperate piece spot welded in. I did mine by cutting down each edge so i could push it back to see a little better, found and center punched the spot welds, use a spot weld drill bit to remove. I photoed the vin in place and then cut it out again with a photo for back up. You could always weld / pop rivit it on to another panel.
    [​IMG][/IMG]
  3. jamesa Forum Junkie
    Abz
    Are you retaining the heater and going to use the car for RACMSA Motorsport ?
    (That seam / seal serves as a firewall between the engine bay and the driver)
  4. RyanMac Forum Member
    No james I am not going to use it for racmsa and my car doesn't have a heater or anything like that. The heater and all components/associated parts have been removed from the car.
    It's a mod people do, but could affect not perhaps your use, but someone else's in the future. I wouldn't buy a car with it removed for eg.
    It creates space, but it's no biggie IMO. A few bits of quite useful tin - amounts to nothing on weight saving.
  6. jamesa Forum Junkie
    Abz
    Fair enough ... shame though ;)
  7. jamesa Forum Junkie
    Abz
    Agreed ...
    Unfortunately I`ve seen several cars where that area has been compromised with fuel lines / filters etc ...
  8. danster Forum Addict
    You can just put a box over the heater motor air intake, and a duct to supply air. This then retains the sealed bulkhead for Motorsport use.
  9. MK1-Tron
    Staffordshire
    Duct on the Reeves MK1
  10. RyanMac Forum Member
    it was all removed when I got the car and the hole that was left covered over.
