Mk1 Scirocco, ABF, ITBs, DTA, etc - update 20.12.17 - JMR gearshifter in
Discussion in 'Members Gallery' started by mr.brown, Dec 18, 2017.
  1. mr.brown
    mr.brown Paid Member Paid Member
    Sunny Surrey
    **Apologies - I don't know why the pics are so big**
    Rewind to August 2016 and I bought this - for the 3rd time.
    ****ed around with a few looks
    Went all Edition 38
    And then these came up for sale.
    Oh what to do with them? Slap them on the existing TSR 2.1 8v?
    Nah
    What else to do with spare cash but invest in the Welsh economy - 2Y with 02K bits + Quaife + 4.25FD. And a lightened flywheel thrown in for the hell of it.
    Painted
    Fitted with new Sachs clutch
    Dropped in with a KR/ABF hybrid engine.
    Good beginners' suspension
    And to keep the flappy bonnet in place
    In preparation for the coming wiring fest I fitted a mk2 Golf fusebox holder.
    To make room for this little lot
  2. mr.brown
    Sunny Surrey
    New SKF driveshafts fitted
    A few JMR bits - dizzy block off/coil mount
    Close up
    Flange
    Mounts
    Mk3 alternator/water pump pulley set up
    Random bits - modified cambelt cover, adjustable Fuel Pressure Regulator, Sytec fuel filter
    Just for the sake of a bit more clearance I fitted a Spal fan
    I then removed the factory oil/water cooler in favour of a Mocal Oil Cooler and thermostatic take-off
    Polo GTI oil filter - again, just for an extra bit of clearance (and also much easier to remove)
    Checking some of my previous work - I fitted this sender back in 2004/5
    And a new tank went in at the same time. I also drove to Holland to pick up a NOS filler neck. It seems to have done it's job..
  3. mr.brown
    Sunny Surrey
    Here's why I fitted the mk2 Golf Fusebox holder
    Four new relays - ECU, Wideband controller, High and Low beams. Thanks to RJ for his posts and help and advice :thumbup:
    Also, fitted a mk4 era battery top fusebox. As you can see, I've fitted two new power supply wires to the fusebox to replace the single factory one
    Dismantling the factory wiring (which was from a mk2)
    Starting on the ECU wiring
    Bit neater
    Injector harness
  4. mr.brown
    Sunny Surrey
    Few more bits added - mk3/4 era expansion tank, Mocal catch can, Wiechers strut brace
    Air temp sensor
    First electrical test
    Started off at 3.5 bar with the G60 injectors but later changed to bigger "Red Top" items and dropped down to 3 bar
    USRT "Mushmeister"
    With some Toyotec magic I was able to get in running well enough to get it through it's MOT
    As part of the next phase in this project, I need to cut down the airbox a few inches
  5. Toyotec
    Thanks for taking time and share these developments with us.
    I appreciate it takes a lot of time these days.
    Good on you for showing off what you have been up to :clap:
  6. Savagesam
    I like that a lot, I think my next (old) car will be an ABF on ITB's. I really wanted to on my old golf but funds said otherwise.
    Car looks great! :thumbup:
  7. dubztubz Forum Member
    ireland
  8. mr.brown
    Sunny Surrey
    Cheers chaps. Got a bit more done -
    So the reason for cutting down the airbox was so that I could fit this
    The horizontal rod goes through the bulkhead (ignore the crappy bolts, I'll replace them all later lol )
    Luckily I found some kit-car vents so I have still have heat-to-feet when I want it (this is a view looking up from the floor)
    This is the bracket that has to be mounted to the other side of the bulkhead
    johnnyfication and Yoof like this.
  9. Farmerchris
    Farmerchris Paid Member Paid Member
    Great build! Looks realy tidy.
    I'm considering changing my oil cooler for a thermostatic sandwich plate like you have done.was it a straight swap? Or did you have to shorten the center oil pipe which the filter screws into?
    Cheers chris
  10. jamesa Forum Junkie
    Abz
    :thumbup:
    What ~ engine bhp, exhaust manifold and system (inc. diameter) please ?
  11. mr.brown
    Sunny Surrey
    I had to get a shorter centre piece - I had one from a mk1 lying around which did the job - although lots of cars (even new ones) have the same pipe. The Mocal kit comes with a slightly wider pipe which screws on over the original pipe and keeps the sandwich plate in place. That said, I've now removed the Mocal and gone back to oil/water cooler (winter mode lol)
    Engine is unmodified so expecting anything from 150 upwards. Manifold is the generic 4-2-1 that everyone seems to sell - 400 from Heritage or 200 from ebay. System is a single box off-the-shelf s/s 2.25inch from Powersprint in Germany.
    At the moment the 4 branch is jammed up against the steering rack so it's going to have to modified or replaced by something custom. As you can see from the last pic, with the JMR linkage the exhaust no longer needs to swing to the left - hopefully I'll be able to use one of my ABF manifolds and a custom downpipe.
  12. jamesa Forum Junkie
    Abz
    Thank you.
    My Mk1 Golf is running a 9A on ITB`s, manifold is an Ashley (I think ?) to a Supersprint system from the previous modified 8v ... I was looking for a comparison re. possibly needing to run a larger diameter system.
  13. mr.brown
    Sunny Surrey
    Hopefully I'll have mine mapped and rolling road'd in the next couple of months :thumbup:
    Cleaned up some wiring yesterday - so no longer embarrassed to take full interior shots lol
  14. GVK
    Looks great, must sound great too! :thumbup:
  15. 16valver Forum Member
    Don't think I have ever seen the Scirocco before - love it
  16. Jon Olds Forum Junkie
    Very nice work
    Jon
  17. zx10rdazza Forum Member
    S.Yorks
    Mk1 Scirroco, my favourite VW of them all. :thumbup:
  18. mr.brown
    Sunny Surrey
    Thanks for all the positive comments. It's now mapped and just needs the exhaust tweaking. Then I'll be halfway to where I want it to be lol
  19. Toyotec
    And when the exhaust is sorted, then something else will happen, then...
    Cars...lol
  20. Stew1803 New Member
    Laurencekirk, Aberdeenshire
    that dizzy block off/ coil mount is EXACTLY what ive been looking for for weeks! I cant see it on the JMR website though? Ill have to give them a ring me thinks
    knarfmk1 likes this.
