Mk1 Spot lights
Discussion in 'Mk1' started by PMH169, Mar 1, 2019.
  1. PMH169 Forum Member
    My Mk1 GTi has the front grille fitted with the four lamps.
    Am I correct in saying that the inner two are spot lights and not front fog lights.
    The fog light switch on the dash has two positions.
    The first does not appear to do anything
    the second position illuminates the rear fog light.
    From what I have read the two inner spot lights come on with the
    headlight main beam.
    Do I simply wire the spot lights into the main beam circuit ?
    At the moment they seem to be connected back to the fuse
    box through yellow wires with white tracers.
    Any help appreciated.
    Thank you
    it depends! the original grilles had fog lamps fitted, but most retro fitted parts woudl be spot lamps.
    got any pics/part numbers?
