MK1 top mounts
Discussion in 'Track Prep & Tech' started by LeLapin, Oct 9, 2016.
  1. LeLapin New Member
    USA
    Looking for advice on MK1 Top Mounts on my track day set up.
    My problem is strut mounts do not last more than 2 track day events.
    I am currently running lowered springs, Koni Sports and Poly bushings and none racing tires(tyres). My top mounts are reinforced to roll cage ... so very stiff. I do run 2 degrees negative camber if that matters.
    Interesting enough, my gravel setup seems to be holding up.
    Any thoughts?
    Thanks
  2. jamesa Forum Junkie
    Abz
    What mounts are you running and ... any pictures ?
  3. LeLapin New Member
    USA
    I should have though to mention...
    I have tried Meyler and Febi mounts.
    ecp supposedly do lemforder make ones, so id try those for starters :)
  5. MUSHY 16V
    aberdeen
    If it's a track car i'd fit solid compbrake mounts or if it still on the road bonrath top mounts though the latter is had to get now
  6. mickey marrows Forum Member
    Seeing as you're in the US have you considered investing in a set of Ground Control top mounts? Or are you class limited?
  7. LeLapin New Member
    USA
  8. LeLapin New Member
    USA
    ECP??
    Sent from my iPhone using Tapatalk
  9. jamesa Forum Junkie
    Abz
  10. LeLapin New Member
    USA
  11. mr.brown
    mr.brown Paid Member Paid Member
    Sunny Surrey
  12. jamesa Forum Junkie
    Abz
    I use the Compbrake eccentric mounts, set for 5` positive caster with 1.5`camber (hillclimb / sprint car ... as yet untested !)
    LeLapin likes this.
  13. LeLapin New Member
    USA
    I found a set of used Branth(so?). Will have to see how they hold up.
  14. jon23 New Member
    Herts/beds
    what coilovers are any of you running for solid top mounts ive got the gaz gold solid adjustable top mounts, but it raises the car 30mm, if i was too lower the car a further 30mm it will make the car too crashy and wont have sufficent damping to be any good.
    do i need custom coilovers or is there a set out there that can accomodate the solid top mounts
    cheers jonny
  15. jamesa Forum Junkie
    Abz
    I run Leda coilovers ... spec`d for my application.
    Can Gaz not provide you a custom damper ?
