hey guys just woundering if any 1 can help i was bored tonight so i looked through ebay for ways to make my mk2 quicker. I looked at chipping it 1 of the links i went on said something about only doing engins from 92 - 94 the chip clearly stated 2e so i thought my luck was in i kept the page up and removed my ecu from my car split it open to find no where to put a chip just a big silver box i tapped the ecu part number into etka and it brought up something that just said digifant my ecu sure enough says digifant on it but has df1 above it how do i chip my ecu or can i what is the big silver box any help would be great cheers
If the 2.0 engine is in a digifant Mk2 then the simplest route is to keep the Mk2 ECU and buy a chip for it. A few on here have bought BlitzChips ones from ebay, with reasonable results.
all the bits in the engine bay including ecu are from the mk3 will a 8v digifant ecu from a mk2 run my car if so ill just do tht and does any 1 know if you can chip the mk3 8v ecu or what the big silver box is for
You don't want the ECU from the Mk3. If your Mk2 is an 8v GTI already, use whatever came with that. You need to swap the cylinder head over too.
i have put all of bits i took out of the mk3 in as the mk2 was only a driver to start out with im just trying to find out if the mk3 had the right ecu and how easily i can chip it
