MK2 Bulkhead Grommet...
Discussion in 'Electrical' started by Zender Z20, Dec 3, 2021.
  1. Zender Z20
    Did this a while back and posted it elsewhere, so might seem familiar to some of you.
    Was a weather resistant / reversible solution to running a reasonably thick bundle of wires into the engine bay.
    Utilises the largest of the existing plastic grommets, the center of which is cut out so as the groove created will accomodate the new rubber insert.
    Piccies are of different views / stages and hopefully self explanatory - the additional grommet is a generic one and generally available, however I got this particular
    one here (no connection to them).
    https://www.stmotorsport.net/product-page/bulk-head-panel-wiring-harness-grommet-rubber-seal
    The last image is of it in-situ...
    costel1969 likes this.
    Nice.
    I think that's an updated version of an old Lucas electrics 2 inch standard wiring loom grommet.
  3. Zender Z20
    Don't have one to know what can and can't be done, but maybe an opportunity for someone to 3D print the plastic part / prefit the rubber grommet, rather than people cannibalizing the original VW one?
  4. Tristan
    Wouldn't it break when you tried to snap it in?
  5. Zender Z20
    Maybe someone with a printer could let us know, the original VW grommet is made of that semi-flexible plastic, so no issue with a bit of pressure.
    If 3D'ing is only capable of rigid items, could improvise and have an inside and outside ring that clip together through the bulkhead?
  6. Tristan
    Or a snug fit with a bead of clear sealant...
  7. caddyboet
    Durham
    Looks really neat. :thumbup:
  8. rubjonny
    couldnt you just use the LHD engine/lighting loom holes tucked in the corner just above the chassis leg?
  9. Zender Z20
    Likely plenty of other solutions, the wires I was running combined to make quite a bulky loom and any of the other grommets would've been a tight fit / risked chaffing.
    You can also get at the larger one quite easily from the inside if you're blind feeding wiring through.
    The inner rubber piece will hopefully stop moisture and fumes because of that tubed collar, not done in the photo but you can cable tie it if needed.
  10. AndyBa Paid Member Paid Member
    Sheffield
    As I found when replacing the bulkhead grommets with some off ebay. The quality of some is really crap/badly moulded as well as being made of different material - eg rigid like the original referred to in this post.
    Not good for providing an effective seal.
