Mk2 golf cl
Discussion in 'Members Gallery' started by stevencooke, Mar 20, 2019.
  1. stevencooke Forum Member
    Another section of rear floor finished today, not a alot left now.
    First Pics of rear floor blasted ready for epoxy primer.
    Epoxy primed.
  2. stevencooke Forum Member
    So i'm back on the golf again. Still stripping rubber undercoat from back end, there's lots of awkward spots so could take some time.
  3. stevencooke Forum Member
    Removed some more rubber undercoat, don't look a lot for a days work .
  4. stevencooke Forum Member
    Big milestone today, I've officially finished removing all the vw rubber undercoat. Next Is to do a little welding and get the
    underside sealed and painted.
    Some pics of the rear boot floor underside after blasting today.
  5. stevencooke Forum Member
    Epoxy primed.
  6. stevencooke Forum Member
    Zinc plated fasteners.
  7. stevencooke Forum Member
    Applied some paint to the engine bay today, I had a change of heart on the colour I chose first time round.
    Remember the engine bay when I started this project.
    New colour applied. I will wet sand it then give it another finishing coat as I did get some runs.
    Looks grey in pics but it is blue.
  8. stevencooke Forum Member
    Chopped some rot from passenger side rear sill wheel arch.
    Made up a repair piece for the inner arch and welded in.
    Weld primer applied ready for outer arch repair.
    Outer arch repair piece welded in and grinded down.
    Skimmed with first layer of filler, This wont need to be perfect as the outer sill will be stonechipped and the outer arch will
    have a cover fitted. I'll still get the repair as best as I can. Both rear arches have some dents to sort also.
  9. stevencooke Forum Member
    Been cleaning up the floor inside. Removed sound deadening and dashboard.
    Before pics
    After Pics
  10. stevencooke Forum Member
    Still plodding along with the golf In any spare time I get. I've let stress get the better of me over the last few weeks so progress has been slow. I'm hoping to have the underside finished by Christmas.
    Sandblasted the inner dash panel windscreen aperture as there was some surface rust present.
    Finally finished all the welding to the shell.
    Pics of drivers side rear of sill inner arch repair process.
  11. stevencooke Forum Member
    I'm still trying to get on with the project but lost motivation the last few months. The stonechip coating I applied was cheap and came back to haunt me, I found myself being able to pick It off with my fingernail.
    So I removed all the stonechip, another week wasted but Tintable raptor will be applied.
    Started prepping internal floor a section at a time. The floor will have black raptor applied.
    Epoxy primed.
  12. stevencooke Forum Member
    Did some more prep to the rear internal floor, epoxy primer tomorrow.
  13. stevencooke Forum Member
    Epoxy primed rear floor.
  14. stevencooke Forum Member
    More prep and primer done to the floor over the last few days. Just have the rear seat base, boot floor and rear arches to prep and prime now.
    Prep to rest of floor and front inner bulkhead.
    Epoxy primed.
  15. stevencooke Forum Member
    Boot floor, rear arches and rear seat base sanded ready for epoxy primer.
    Epoxy primed.
    Raptor bed liner applied wet on wet over primer with a 1.7 gravity gun. Raptor thinned to suit.
  16. stevencooke Forum Member
    More progress today. Main floor scuffed another coat of epoxy primer then applied Raptor bed liner
    Epoxy primed.
    Raptor Lined.
  17. stevencooke Forum Member
    I would just like to say sorry for all the pics. This thread was copy and pasted from another forum and this is how the golf stands at the moment, more progress soon.
  18. rubjonny
    loving this, you've done a great job :)
    stevencooke likes this.
  19. H8V
    h8v Forum Member
    Wow. That's amazing dedication. Well done.
    By the way, what's the interesting copper pipework clipped to the wall?
  20. stevencooke Forum Member
    Had it made up to trap moisture from my compressor. It does work but you have to drain every few days depending on how much you use your compressor. Dry air is vital when sand blasting otherwise you just get frustrated by the sand getting wet and clogging gun constantly. Thanks for reading.
    Vinnie likes this.
