Mk2 golf cl
Discussion in 'Members Gallery' started by stevencooke, Mar 20, 2019.
  1. H8V
    h8v Forum Member
    Ah, makes sense now. Thanks for explaining. Looking forward to following the Golf progress.
    stevencooke likes this.
  2. stevencooke Forum Member
    Still trying to get on with the golf, not a lot to show but progress is progress
    Stripped the paint off the tailgate.
  3. stevencooke Forum Member
    Underside re sanded after removing old / first lot of stone chip undercoat.
    Repaired the dented chassis rail, never got it perfect but It's 10 times better.
  4. stevencooke Forum Member
    Re seam sealed, a bit ocd.
    Painted inside the front chassis legs.
    Masked up underside and rekeyed for another coat of epoxy primer then straight on with raptor.
  5. stevencooke Forum Member
    Tinted raptor liner applied. Looks different shades but It's just the light and camera. I went on a bit thick but spent most of my time rolling around on the floor getting tangled in airline.
  6. costel1969
    Absolutely top notch work and a credit to you
  7. stevencooke Forum Member
    Managed to get the back underside prepped up ready for another coat of epoxy primer ready for raptor.
  8. stevencooke Forum Member
    Raptor Applied, A bit thick again but hopefully plenty of protection.
    Vinnie and erreesse like this.
  9. stevencooke Forum Member
    Rubbed engine bay back down for a few more coats of paint, no runs this time so I'm pretty happy. I've also started filler/body prep, still a long way to go.
    Engine bay prepped and spot primed.
    More paint.
    De masked.
  10. jmsheahan CGTI Graphics Designer
    Wiltshire
    Just WOW. The attention to detail on this is superb, well done!
    Currently in the process of bare metalling, Epoxy Mastic and Raptor'ing mine and if it looks half as good as this I'll be dead happy!
    Keep the updates rolling :thumbup:
  11. stevencooke Forum Member
    Thanks mate, do you have a project log I can check out.
  12. jmsheahan CGTI Graphics Designer
    Wiltshire
  13. stevencooke Forum Member
    Starting to get there now, slow progress but progress.
    Painted inside rain tray, first more primer.
    Applied 3 coats of colour. This was a nightmare to get in with the gun.
    Prepped some parts ready for paint and reassembly.
    Parts painted in black gloss vht epoxy.
  14. stevencooke Forum Member
    Done some filler work and lots of prep to passenger side.
    2K filler primed.
  15. rubjonny
    nice work! scuttle is one thing I'm not looking forward to. mine is going to have to come out as with a sneaky peek with a mirror i can see rust creeping along the seam up on the inside
  16. Mk2Singh Forum Member
    Amazing attention to detail! Really good work. Whats your process for cleaning and removing the old underseal stuff and wax oil? Look forward to more updates
  17. stevencooke Forum Member
    Thanks for your kind words. Petrol and lots of old rags plus heat gun will remove the wax oil. For the vw rubber undercoating I found it easier to use a scraper and wire wheels in a drill. As you can imagine this job is the worst and very messy, just a case of getting stuck in and trying to switch off from the job in hand. Good luck.
  18. stevencooke Forum Member
    If the rust is just In the seam you should be able to open up the seam and sandblast the rust out. Depends how bad it is. Thanks for taking the time to read and comment.
  19. rubjonny
    trouble is its right up underneath. theres various spots of rot in the screen surround too so I'll be able to fix is all up at the same time. one day, once I get myself a garage big enough to do it. I keep telling myself that anyway :lol:
  20. stevencooke Forum Member
    Before this golf I had a red mk2 driver, I did aload of welding to it but just got to the point when a better shell was needed. The rot around the scuttle travelled into the upper inner dash rail and was completely rotted out around bonnet hinges etc. Good luck with yours when you get round to it, do you have any pics on the forum of yours.
