Mk2 golf cl
Discussion in 'Members Gallery' started by stevencooke, Mar 20, 2019.
  1. rubjonny
    dont even mention bonnet hinges, its already well gone around the driver side hinge :lol:
    https://clubgti.com/forums/index.ph...-then-abf-now-abf-management-widetrack.85893/
    it'll either last till I can fix it proper or I'll have to be crushed into a small cube once all the good bits have been taken out. be a shame to get id but at the end of the day its nowt special just a proper poverty spec gti 8v with a massive pile of stuff thrown on top
    stevencooke likes this.
  2. stevencooke Forum Member
    Been carrying on with bodywork, lots of time and patience which I lack to be honest. Drivers side ready for more epoxy primer then 2k filler primer. I cannot believe how many small dents impressions in the metal I've found, hopefully filler primer will help level it all out.
    Here's some pics, sorry nothing really exciting.
  3. stevencooke Forum Member
    A few more pics of progress, feels like I'm working 2 jobs at the moment.
    Pics of drivers side masked up, epoxy and 2k primed.
    Guide coated.
    Flatting down with 400 wet.
    High spot here, looks like a missed a dent.
    Roof flatted, dents found, filled ready for epoxy and more 2k primer.
    Primed and guide coated.
    Flatted with 400 wet.
    Sirguydo and erreesse like this.
  4. stevencooke Forum Member
    Not updated this project In a while so thought It was about time I did.
    First pics, spray some paint on passenger side, this will be flatted and then final coats applied.
    Front subframe build up.
    Fitted to shell.
    Cleaning blasting and painting front end parts.
  5. stevencooke Forum Member
    Had a load more parts blasted and powder coated.
    Managed to pick up some half decent seats.
  6. stevencooke Forum Member
    Pedal box refitted.
    Cleaned and painted steering Coluum In preparation to get a rolling shell.
    Started sound deadening.
    Fitted More parts to the front subframe.
    Drivers side paint.
    Rolling shell again, I didn't take any pics of the rear end build up as got carried away. Ignore the gold wheels as ill be painting them white eventually.
  7. stevencooke Forum Member
    Tailgate sanded to bare steel.
    Tailgate epoxy primed.
    Passenger wing sanded to bare steel ready for epoxy primer.
    Drivers wing sanded to bare steel ready for epoxy primer
    Epoxy primed.
  8. stevencooke Forum Member
    Some more bits and bobs done over the last few weeks. Sorted the rear panel out after my balls up removing the center badge and warping it slightly.
    Ended up skimming the whole panel, was just a light skim.
    Guide Coated.
    Block sanded.
    Epoxy and 2k filler primed.
    Guide coated Again.
    Flatted again with large sanding blocks, center still wasn't quite right so more filler added.
    Epoxy primed and given first coats of paint.
  9. stevencooke Forum Member
    Rebuilt the gear selector mechanism and gear shift box.
    Before, the rest was just as rusty and worn out.
    Stripped down and sandblasted ready for some primer and paint.
    Painted and re assembled with a new rebuild kit.
    New Foam weather seal fitted to top before fitting.
  10. stevencooke Forum Member
    Gear selector box and mechanism refitted.
    Front cross members re fitted.
    Petrol tank cleaned and scuffed up ready for a coat of black raptor to smarten it up.
    Plastic primed and painted.
    Fuel lines re fitted along with new clips.
  11. stevencooke Forum Member
    Fuel tank fitted with new breather pipe's and stainless jubilee clips.
    Fuel tank re fitted.
    Front windscreen surround finished off and primed.
    First coat of paint on roof.
  12. stevencooke Forum Member
    Started stripping the engine ready for a rebuild, pics before stripped.
    Pics during strip down
    Bare block, first degrease.
  13. stevencooke Forum Member
    Engine block had a electrolysis bath for 48 hours then a week in a citric acid bath.
    Engine block was then dry'ed off and masked ready for some paint.
  14. stevencooke Forum Member
    Engine block epoxy primed.
    Painted and 2k clear applied, photo's don't do it justice.
  15. stevencooke Forum Member
    Block back up on bench after giving the bores a hone.
    Crankshaft refitted along with new bearing caps.
  16. stevencooke Forum Member
    Sandblasted lots of engine bits.
    Painted.
    More parts fitted to engine block plus new core plugs.
    Had loads more bolts etc zinc plated, literally gathered together every nut, bolt etc i could find.
    Vinnie and erreesse like this.
  17. Savagesam
    Damn, that’s a lot of work. Looks great!
    do you like black by any chance? [:D]
  18. stevencooke Forum Member
    Cheers mate, also blacks just a safe option and not so in your face. Its been alot of work for sure hopefully start seeing the finish line soon.
  19. copeidge
    copeidge Forum Member
    Lovely work mate! really impressed. I'm currently going through paint process, my first time with a proper gun. I opted to 1k base and clear. Did you use 2k - no clear?
    cheers :)
  20. stevencooke Forum Member
    Thanks mate appreciate the comments. I've used 2k direct gloss but might basecoat and clear coat it as I'm not happy with the finish. I'm sure 1k will do just a good a job might just need more coats.
