As title says. I'm after picture references of all brake and flexis for the rear of the golf, I'm really stuck. I'm making my own from scratch but i didn't take the car apart so I've got no reference pics.
I was going to remind you that there are under car pics in the front of the Haynes manual, but then I checked out your epic build thread and decided you deserved better than that. Starting under the bonnet, there are two T pieces which split the two lines from the MC into the diagonal front left/right rear and vice versa configuration: After being clipped (good luck sourcing all the necessary clips) to that bracket down the bottom, the two rear lines travel in a channel on passenger side: then here I assume the U bends are to give some flex to help fitment to the pressure regulator: In this shot you'll see the line heading from the regulator to the drivers side. It goes above the exhaust box heat shield. Regulator and bracket: Passenger side Beam flexi: Passenger side line runs along top of beam: Wheel flexi: Drivers side beam flexi (digifant pump/filter assy): Good luck!
Does anyone know of a part number or some info for a braided hose for the passenger side beam flexi and drivers side beam flexi? *sourced these now from goodridge *
