mk2 golf vr6 OBD problem
Discussion in 'Electrical' started by norm_str, Feb 2, 2020.
  1. norm_str New Member
    hi, ive done vr6 engine swap in my mk2 but i can't get OBD port to work and its not communicating, does anyone know what problem it could be i just don't know where else to look ? thanks
    first off does it have the immobiliser box or not, and what kit are you using to scan the ecu? some aftermarket scan tools arent compatible with VW ecu.
    the port needs permanent live to pin 16, earth to pin 4 and diagnostics to pin 7. on non-immo ecu this goes straight to ecu pin 43, with immo it is connected to the immo box then the box is connected to ecu pin 43. really early vr6 have a 2nd yellow wire from ecu pin 21 to port pin 15
  3. norm_str New Member
  4. GVK
  5. norm_str New Member
