Mk2 Golf with 3.2 v6 conversion (fuel rail question)
Discussion in 'General Vehicle Chat' started by Marky4787, Jun 20, 2022.
  1. Marky4787
    Marky4787 Paid Member Paid Member
    Northamton
    Hello again
    so I'm about ready to put the engine in
    got all mounts in place
    VR subframe bolted in today
    Trackslag down pipe slotted in
    flywheel and clutch installed and gearbox attached to engine
    ecu has been coded
    mk4 pedal and braket obtained
    but I noticed the fuel my on this 3.2 doesn't have a fuel return and I need to know my option's
    mk4 r32fuel rail?
    earlier 3.2 fuel rail with fuel return
    2.8 fuel rail?
    2.8 4motion fuel rail?
    Someone said possibly FPR (which one)
    at the moment it has a vr tank with pump as it use to have a 1.8t
    also, I think I know the answer but I went about getting the accelerator pedal out today as it's going to be dbw, how the hell do you get it out without disconnecting everything? clutch pedal in the way, steering joint in the way! does it come out or is it a disconnect everything or cut it out?
    thanks again all.......wont be long and it'll actually be done....hopefully
  2. dodgy
    Have a look at fabless manufacturing website, think they sell a mk5 filter bracket for conversions, think the filter has a return inbuilt, perhaps it can give a bit of inspiration for your project.
    As for the pedal, I removed the whole box as converted from auto, have got to try and remove a mk3 one soon and think may just chop it up in situ,looks worse than a mk2 to do.
  3. Marky4787
    Northamton
    You sir are a legend! I’ll get one of them ordered this week! As for the pedal my little hacksaw will be coming out today
    Thanks
