Mk2 GTi Syncro Build - Operation MOT
Discussion in 'Members Gallery' started by Savagesam, Jan 12, 2020.
  1. Savagesam
    Definitely not show car, a very clean, useable sleeper.
    An Odyssey PC680.
  2. Vinnie Paid Member Paid Member
    Sleepers are the best [:D]
    Savagesam likes this.
  3. Savagesam
    Got loads of parts to clean up, but it’s just so boring.
    Got fed up after I couldn’t find the proper tool to undo the last banjo.
    erreesse and Vinnie like this.
  4. Savagesam
    Well I have decided to crack on with my speedo.
    Following John’s pictures & advice.
    So stripped my donor clocks down (thanks @dodgy)
    Then got rid of the bits I don’t need for now.
    Now we begin, step 1: cut the mk2 metal bracket so the Corsa needle motor fits. You’ll have to excuse my cutting, I got a bit excited and went at it with the grinder, should have waited until I got a small hacksaw or something.
    Which left us with this.
    then trim down the brace bar,
    Then cut the Corsa stuff up, so we can use the mileage motor mount and board mount.
    which leaves us with this to start with.
    And something a little like this, before the trimming properly starts tomorrow.
  5. Savagesam
    Got the motor fitting a bit better, getting there.
    Got the Corsa mileage motor gear off and onto the mk2 pin.
    then assembled it, lowest mileage mk2 ;)
    getting closer..
    Once that’s fitted, I need to chop this up. Leaving the oil PCB in place and get it sitting in the correct place, so that’ll be fun!
    erreesse, dodgy and Vinnie like this.
  6. Savagesam
    Speedo break:
    Chopped off the rod linkage holder,
    And paint! Don’t have my grips to get the ends off, will grab them from work tomorrow.
  7. Savagesam
    Well I finally finished it.
    The arms were on bloody tight and I didn’t have a spanner big enough. 5A2D47AE-D033-4D80-A816-F66E99EBA467.jpeg
    And now it’s pretty.
    erreesse, Vinnie, dodgy and 1 other person like this.
  8. dodgy
    I bought a track rod removal tool years ago so I could change the set on my clio van when I widetracked it, going to be using it again on the mk2, makes it light work the job and without removing rack from car.
    Nice work on the refurb, looks great.
  9. Savagesam
    Yeah dad has the tool but that’s at his
    Now I don’t have mk2 mounts the subframe is super easy to get off
    Vinnie likes this.
  10. Savagesam
    Well I’m hoping it’ll be the last weekend I work on it before it goes onto the rotisserie for tidy up and underseal.
    So first up, front shafts. I have a slight issue, I need another TT short shaft for the shaft to get the length and I forgot to order pipe. Going well so far, right?
    But managed to get one to length. And this was all I had to show for it.
    I then moved onto moving my prop bracket, again! As it’s too low, I can’t ever get 3” of exhaust past without it touching the floor.
    So, let’s just turn the bracket upside down, and modify it a little.
    Loads more room.
    Then modifications to the prop,
    Well, I tried anyways. I managed to weld the nuts on the same side they were originally on! well done Sam.
    Anyways, managed to get them welded on the correct side and popped it back in to start making brackets up, again!!
  11. Savagesam
    Well my plans all went to **** when I realised I didn’t have half the bits I thought I did. So here we are.
    I trial fitted a trackslag 3” back box, that won’t fit.
    Then.. off we come!!
    Attacked some bushes with some fire 1CA0DEE7-D863-441D-825D-BCF8A640CF35.jpeg
    cleaned up some welds and we are ready to go
    I also got a free sandblaster. works a treat.
  12. BISSONE Forum Member
    South Staffs
    Free sand blaster? You have nicer friends than me ;)
    cupracraig likes this.
  13. Savagesam
    I found it on marketplace! A lady was just giving it away. Can’t say no to a freebie!
  14. Savagesam
    Sooo.. I got a 3D printer and dad had an issue of this part, being butchered by the previous owner.
    So I designed one up on CAD for him, and printed it. Few teething issues, but nothing I can’t sort.
    dodgy and afbiker02 like this.
  15. Tristan
    What are you using, PLA? Hairspray on the printing table?
  16. Savagesam
    PETG. No this is stock form Ender 3 with nothing on the bed.
  17. cupracraig
    South West
    good updates dude. the 3d printing is a good idea, what a rsult on the sand blaster! i deleted facebook in december and i do miss the marketplace
  18. Savagesam
    I hate the place but I found I was struggling to get parts for my car so I made an account just for marketplace.
  19. Savagesam
    A slight redesign and the fit is perfect.
    Vinnie and erreesse like this.
  20. Savagesam
    Well no update for the moment but in the next couple of weeks. A LOT should be happening.
    Watch this space.
    NateS2 likes this.
