Me again, just another query regards mk2 90 spec wiring for an ABF swap. I quite fancy a later driver model as the small bumpers and later loom seem a cheaper option to swap all mk3 abf kit over to. The thing is does the mk3 tank/pump etc bolt straight into the mk2 shell and regarding wiring to run the pump/sender unit etc, will this be a plug and play affair the same as the engine loom??. Thanks for your patience all who have answered previous posts.
1. yes 2. yes, but you'll need to strip mk3 pump loom out of the rear loom and run it alongside the mk2 rear loom
