mk3 golf aBF - fitting crank sensor
Discussion in '16-valve' started by Icy, Apr 21, 2008.
  1. Matt82
    Matt82 Forum Addict
    GTI Scene
    really? 20nm is basically hand tight
  2. G60Dub
    G60Dub Forum Member
    Angus
    Yeah that's what I thought so when you posted I went back and double checked & here's where it gets confusing...
    Workshop Manual->
    Engine, Mechanics ->
    4-cyl. injection engine (4-valve), mechanics->
    17 Lubrication->
    Removing and installing parts of the lubrication system->
    Item 24 on diagram v17-0533 - Oil Drain Plug 40NM! FAIR ENOUGH!
    But if you look under the Maintenance Manual:
    Engine Oil: Drain or extract and top up; Renew Oil Filter:
    Torque settings for oil drain plug:
    Note
    Remember that the following torque details must not be exceeded. Excessive torque can cause leaks in the area of the oil drain plug or even damage.
    t Engine code ABF: Sheet metal sump 40 Nm
    t 4-cyl. engines: Sheet metal sump 30 Nm, aluminium sump 20 Nm
    t 6-cyl. engines 30 Nm
    Well done VW! From experience I think 40NM is a bit tight as I always struggle to get the sump plug off and I always fear that it's seized but hey I'm getting old and feeble. :lol:
    20NM did not feel safe - I went to 35NM this time so hopefully I wont drop my oil and 5000 miles from now I'll fight again to get the damn plug out
  3. Jogort New Member
    hmmm, my post disappeared. Nevermind, reviving an old thread as I have a mk3 gti 8v and am replacing the crank sensor this week (its on order) today I was going to remove the old one but found a nice rusty rounded allen bolt holding the sensor in place.
    Any ideas how I can remove this with limited tools and a very tight working space (dont want to have to remove the whole front panel)
    TIA for any help
