Hi Guys I'm looking at widetracking my Mk3 and was wondering if anyone knew of a wider rear beam that I can use or advise on weather or not putting a 10mm/15mm plate between the beam and hub would be safe? Any help would would be great! Thanks! Jake
fair few widths available: http://clubgti.com/showthread.php?220814 if your beam is in good nick I would just get stub axle spacers use longer bolts of the right tensile and it'll be perfectly safe, the equivalent of fitting a wider beam
Hi Jonny, cheers for your input, I had the same thought using spacers between the stub axle and beam, I'm going to use 15mm plate milled to the shape of the stub axle with some longer bolts, thanks for your help dude!
