Hi guys does anyone know what i need to to wire in an amp to my standard head unit,there are some blank plugs in the back of the head unit that have amp writen on them so i think there must be something i can buy. I founf the remote output in the blank block but need the signal output Here are some pics of the stereo As you can see i found which one is the remote switch feed and fitted the Blue wire
You need to replace the yellow block with an 'Autoleads PC3-11' lead giving you 2 pre outs & a blue remote switch. (on eBay here for just under 10 http://cgi.ebay.co.uk/PC3-11-Autole..._Cabling_ET&hash=item5ae0f85454#ht_500wt_1054) Very in depth guide to mk4 ice here http://uk-mkivs.net/forums/t/177496.aspx
I have just wired up an amp to my factory MK6 head unit. What a nightmare on the newer stuff due to can-bus systems. You can use a phono out converter but its just another thing to power. I took straight from the speaker outputs from the HU to the amp and the only other one to find is a remote. NONE of the accessories in the MK6 are turned off when taking the key out (Switched 12V) apart from one i found at the ignition barrel. I now have a factory RNS510 running a 500W JL amp and its all hidden so you would never know!
