http://www.jtechperformanceparts.co.uk/volkswagen-golf-mk5-6-scirocco-2wd-24mm-front-adjustable-22mm-rear-adjustable-sway-bar-kit.html http://www.jtechperformanceparts.co.uk/volkswagen-golf-mk7-22mm-heavy-duty-2-position-blade-adjustable-sway-bar.html Links above, more options on all are available on the website, so take a look! Now available from Super Pro - their new range of ARB's. These have had some real thought gone into the design and have some interesting features that set them above the rest in terms of competition. For a start, they are not powder coated, which normally when twisted with the bar flakes off over time and a lot less durable to debris. - The coating used on the Super Pro cars is an elastic polymer based coating that will a LOT more durable in the long run. Keeping your bars rust free and wipe clean! Another feature not seen on the competition is location tabs either side of the inner mounts. This prevents side loading and the ARB becoming pre-sprung and un-central. A nice detail. 2 hole adjustable so you can dial in your preferred balance. These bars will help combat the generic OEM under steer balance of the Mk5 chassis, and reduce the overall body roll. Most importantly WITHOUT increasing or introducing any harshness to the ride.
For Club GTI members, I'd be happy to do a free postage deal on these. PM me, and we'll sort it out for you. Thanks, Henry
