Hi I cannot find what I have done with this part for my KR. its the metal plate which goes inside the central console. Finding a 2nd hand one will be easier if I knew the part number so can anyone let me know what that part is? thank you Matt
Is this what you're after? It was on my 8v, tucked up behind the center console and the aftermarket immobiliser was attached to it (since moved). Few years ago now so may not've remembered correctly but I was told then it was something to do with the 16v. I've no use for it, if you want it PM me your details and I can stick it in the post...
Tweaked some of my settings, not sure if that was the problem. Wonder if others haven't been able to get in touch too! Give it another try in the morning, see how we get on.
seem to recal that shape is for the 90spec electric window relay to clip to, but cant find a piccy of the isv bracket to confirm if its the same or not
Away to you this AM... can you let me know it arrives OK, post has been abysmal this last while and I've lost a few things.
Okay I am confused now about how to attach the ISV ECU to the mounting plate and the relay for electric windows which also attaches. Any images gratefully received.
yeah I'm still thinking the isv plate may be a different shape... the 2 scews on the plate fit to the slotsd on the back of the console, then the isv controller clips to the slots in the other side. to me the relay slots on the plate looks to be for electric window relay as they're offset over to the side. the isv controller mounts centrally IIRC
heres a pic of how it attaches (the number of ebay centre console auctions I had to go thru to find this )
god I'm going cross eyed google image searching isv controller and centre consoles. maybe if the plate was flipped vs pic above you then puch the controller underneath it, and the little dimple in the plate clicks with the latch on the control module
