My efr 7064 big turbo build, will be pic heavy
Discussion in 'Turbocharged, Supercharged or Nitrous !' started by 10mm socket, Nov 30, 2016.
  1. 10mm socket Paid Member Paid Member
    Hi there, guys n gals.
    I'm currently getting together all my items for the 'big turbo build', i have a agu 1.8t in 'tracy' my mk1 caddy pick up. Feel free to chime in, as i need help....lots of it.
    Nx express 15lb bottle and wet injection
    efr 7064...supersedes my efr 6258( still boxed)
    emerald k6 ecu with 3 map switch and map sensor
    clutchmasters fx400
    supertech zirconel valves
    aem meth kit
    ie h beam rods
    seimens deka 750 injectors
    arp diff ring bolts
    innovate afr gauge
    obx slip diff
    waiting on
    arp head stud kit
    arp flywheel bolt kit
    innovate boost gauge
    innovate oil pressure gauge
    still loads to purchase and source
    [​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG]
  2. 10mm socket Paid Member Paid Member
    The turbo in the picture is the efr 6258, the 7064 comes tomorrow
  3. m1keh Forum Member
    That was a quick turbo sizing decision :o
  4. 10mm socket Paid Member Paid Member
    I'd raised the question elsewhere Mike and the 7064 was suggested. Highly recommended by all.
  5. Nige
    Nige Paid Member Paid Member
    See where the weld is really close to the holes ?
    You need to grind that away a little, otherwise the nuts / washers won`t be able to sit flush against the flange and you`ll get issues with the gasket leaking as you can`t tighten them up properly, the weld will stop it pulling against the flange. :thumbup:
    Looking a rather high spec build, what`s the use, Drag ?? I`m guessing it won`t be for the track with that size Turbo lol
  6. 10mm socket Paid Member Paid Member
    Yes Nige, being built for fast straight line road use and drag.
    Nige likes this.
  7. Nige
    Do you understand what I was getting at about the weld ?
  8. 10mm socket Paid Member Paid Member
    I do, I've already noticed it'll be a problem. I'll make sure it's addressed.
    Nige likes this.
  9. notenoughtime
    Essex
    Leroy are you still fabricating your own manifold?
  10. 10mm socket Paid Member Paid Member
    Yes mate, waiting on a t3 merge collector then I'll be on it again.
  11. 10mm socket Paid Member Paid Member
    The new 7064 arrived today, here's some comparison pictures. It really isn't to much bigger, but is very chuffing heavy and is going to require bracing from underneath and the top...I've a couple of ideas.
    [​IMG][​IMG]
  12. notenoughtime
    Essex
    What do you mean it's not much bigger!! What was you expecting, look at the intake size compared to the smaller one and the size of the exhaust housing!
  13. notenoughtime
    Essex
    Probably 3x larger intake I reckon!
  14. 1.8T_mk2
    1.8T_mk2 Paid Member Paid Member
    Hertfordshire
    Could also tap a thread in it and use a high grade stainless stud and a K nut. Depends on the clearance on the turbo side though.
    Looks like it will be a cracking build! :thumbup:
    Welding on that collector is tight!! [8D]
  15. Toyotec
    It this a replacement to the one in the picture?
  16. 10mm socket Paid Member Paid Member
    That one in the picture, will be modified to take the t3 flange.
  17. Toyotec
    Gotcha!
    Just looking at the holes in the flange. You are using M10 or M8 studs or bolts?
  18. 10mm socket Paid Member Paid Member
    Hello chaps, what's your views on performance cams. What's the best out there...schrick, Kent, piper, integrated engineering, cat cams. Would like an all out aggressive cam for big power.
  19. notenoughtime
    Essex
    Any other updates mate?
  20. Toyotec
    It is an open ended question, that could only be answered if you know :-
    What is your perception of a fast car and along with road use, how fast you plan to cover the 1/4mile and at what power to weight.
    Is the component combination you have bought already suitable to achieve the desired ET and trap speed?
    Is rpm of maximum power matched by target trap speed.
    As a result there is no 'best' brand of camshaft, but a camshaft profile that matches what you wish to achieve. This could even be standard
    For example, I can tune a stock ABF engine in a Golf MK2 to achieve 14.4secs @ 96 mph on factory CZM 02A gearing and ~ 975kg of weight. 60 ft was 2.4-2.7 secs
    Such a car is perfectly happy to drive everyday in heavy traffic as well as attack a track with some vigour!
    Similarly, a MK1 with even less weight @ 830kg, a 16v 020 with a 4.25 FDR and maybe a tad bit more power from an engine with less friction, would do the just under 14 secs @ 100 mph with a 2.2 60ft
    However if I was more focused to break into 12s with the same engine, gearing + more engine filling at higher rpms will have to be considered and a camshaft based on previous data could be used to achieve target. And I am being over simplistic deliberately.
    These tasks are not just based on best brand parts, you go buy, fit and that is it.
