My efr 7064 big turbo build, will be pic heavy
Discussion in 'Turbocharged, Supercharged or Nitrous !' started by 10mm socket, Nov 30, 2016.
  1. 10mm socket Paid Member Paid Member
    I had a couple of hours tonight tweaking the exhaust manifold as it warped slightly from the tig welding, I've managed to straighten it back up by cutting two of the runners and tacking back up for now. I have been wetting my gruds with excitement to just mount the the efr 7064 into position and gawp at it in all its glory.
    [​IMG][​IMG]
    Nige likes this.
  2. notenoughtime
    Essex
    Is there enough clearance with the bonnet?
    Nige likes this.
  3. 10mm socket Paid Member Paid Member
    If my measurements are correct then yes. I flippin well hope so, or the grinder is going through the bonnet.
  4. 10mm socket Paid Member Paid Member
    Rebuilt the box last night and once I'd done I found the magnet stuck to the side of the storage tin. Ffs!!
  5. sambo Paid Member Paid Member
    Great build mate, like it alot :)
    Just a note on your proposed rev limit, why is it you are thinking of setting it just below 7k?
    Reason i ask is that turbo and rest of your build will be well up to revving to 8k if not more!
    May as well make full use of your big turbo, would ba shame not to explore wider rev band
  6. Toyotec
    Magnets are a saviour to all sorts of nasties!
  7. 10mm socket Paid Member Paid Member
    Sorry for not updating guys, but things are coming to an end. The engine is in and I've been on with fabricating things, inlet manifold, exhaust system from turbo to rear in 3" and intercooler pipework
    [​IMG][​IMG][​IMG][​IMG]
    [​IMG][​IMG][​IMG][​IMG][​IMG][​IMG]
    Break likes this.
  8. 10mm socket Paid Member Paid Member
  9. Break Forum Member
    wow, great update, lovely exhaust piping.
  10. notenoughtime
    Essex
    Any more updates Leroy?
  11. notenoughtime
    Essex
    Any updates mate
  12. notenoughtime
    Essex
    What's the latest?
  13. vw_singh Events Team Paid Member
    Are those steel boost hoses?
    Thanks
  14. 10mm socket Paid Member Paid Member
    Yes, stainless Steel
    vw_singh likes this.
  15. 10mm socket Paid Member Paid Member
    How she currently sits
    Toyotec likes this.
  16. Toyotec
    When do you believe it will be ready to start?
    Looking well intimidating tbf.
  17. notenoughtime
    Essex
    Any updates mate
  18. 10mm socket Paid Member Paid Member
    Got all this made up and painted
  19. 10mm socket Paid Member Paid Member
    Nitrous power and purge/ meth power and rotary map switch fitted
  20. Toyotec
    On an Emerald they use manifold air pressure compensation, so the sensing line is after the throttle and tapped off the plenum.
    Just seen this by the way.
