Hello all, I bought this car in The Netherlands a few years ago, it started out as a 1 liter 50hp 4 speed car. I'm currently in the middle of installing an AFH 1.4 16v and a 5 speed. I've already managed to damage one motor, a gearbox, shear a starter shaft and strip some teeth off a brand new lightened flywheel... Plans for the future include stroking the 1390 16V to 1620 using factory bits of AEE and BCB motors.
Here's a link to the last dyno run I made. Ended up with 142bhp. Since then I've changed to bigger 45 DCOEs 152G with larger chokes. I've tweaked the timing curve slightly because I run a MAP sensor for load based timing pull, this makes my dizzy work like it has vacuum advance.
