Need help Passat 1994 2.0 2e
Discussion in 'Electrical' started by IgorCRO, Aug 20, 2019.
  1. rubjonny
    its on the inlet manifold, with the blue plug :)
  2. IgorCRO New Member
    thank you very much :)
  3. rubjonny
    actually depending on the age of the engine you may not have a 5th injector... on that note, whats the part number on your ECU?
  4. IgorCRO New Member
    This is my manifold on picture
  5. rubjonny
    ok so thats for later passat 2e code without 5th injector, can you confirm ECU part number to make sure its the right one to go with the engine :)
  6. IgorCRO New Member
    ok will see later what is number on ECU . what is with this two vacuum pipes wich going to servo brake. someone play with this.
  7. rubjonny
    they should both be blanked off on a passat unless it has aircon or some other extras, i guess the blank nipples split out and were replaced
  8. IgorCRO New Member
    ok will se the number on ECU. one more time big thanx you are doctor for VW :)
