OEM MK4 management wiring => Mk1/2/3 harness install FAQ (Now with added dieselness!)
Discussion in 'Engines' started by rubjonny, Nov 8, 2013.
  1. rubjonny
    if its from an audi a3 then its basically identical, from what I can see only real difference is pre-cat lambda is narrowband rather than wide :)
    for immobiliser defeat try toyotec on here :)
  2. benthejettaman Forum Member
    some where in the uk
    No its from an ibiza was looking last nite and looks a lot different
  3. rubjonny
    ah ibiza one is very different, ecu pin side is same as vw/audi so you can use one of the diagrams in my sig to map it, i should have a seat diagram in my sig somewhere too i think, if not pm me and i'll print one
    luckily though the lengths on a seat loom are way longer so that makes the splicing work a lot easier, so silver linings and all that :)
  4. benthejettaman Forum Member
    wish me luck lol
  5. Dezbo New Member
    St.Ives, Cambs
    Brilliant, thanks!
    What wires are needed for the diagnostic port?
    updated OP with port info :)
  7. randomguy82 Forum Member
    New Zealand
    Hi rubjonny,
    Over the last few months I have read many of your posts and very much appreciate you sharing your knowledge. I'm putting an AUM into a MK1 and have just upgraded to CE1 from the early style loom to facilitate this.
    I'd like to activate cruise control once the engine is in the MK1. Have you got any experience in doing this? If it's possible I'd make up a custom panel for the necessary switch and button(s). I think it would be a great feature to have especially here in New Zealand where we are ticketed if travelling more than 4km/h over the limit!
    Thanks again for your posts.
    Matt
  8. rubjonny
    to start with for cruise you'll need to plug the stalk in (or your switch panel) into the black plug on the engine loom, then switch on cruise in the ecu:
    http://www.ross-tech.com/vag-com/cars/vwmkIV.html
    you'll need the speed signal for the ecu, to do this in a mk1 you'll need an MFA cluster and add a wire into the smaller plug on back of the dash:
    T6
    1 - wht/blu - outside air temp sensor
    2 - wht/red - outside air temp sensor
    3 - grn/blk - Fusebox pin B/15 on early models, spade to engine loom behind fusebox on late models (oil temp sensor)
    4 - blk/yel - Fusebox pin A/3 (Gearshift control relay pin 3/L)
    5 - wht/grn - Fusebox pin B/18 (Gearshift control relay pin 5/G)
    6 - wht/yel - speedo signal
    you may be able to add the speed sender to your existing clocks, its screwed into the back of the speedo on the MFA cluster and the mk2 golf unit will fit the mk1 speedo. then you'll probably have to find the 6 pin plug housing and screw it into the back of the cluster with the pcb section inserted, assuming this is there on the non-mfa clocks?
    then after all that wire in the MK4 clutch and brake switches and you should be good to go, see my sig for the full diagram g4aumauqecu.pdf :)
    erreesse and randomguy82 like this.
  9. randomguy82 Forum Member
    New Zealand
    Thanks very much. My S1 loom didn't have a plug for the smaller connector on the back of the cluster. The CE1 loom does and the original non-MFA 1981 cluster does have the place to plug this in (which I have done). Given the cluster has the place to plug this in does that mean that I will have the VSS output once I wire up that 6th pin? Or do all GTI clusters have that plug regardless of their VSS output ability?
  10. rubjonny
    all MK1 equpped with MFA have that plug, but dont have the VSS wire. soem of the later cabrio and i assume citigolf will have it, or those with a high spec stereo factory fitted (VSS is used for speed sensitive volume control) or it was equipped with cruise control
  11. randomguy82 Forum Member
    New Zealand
    Thanks, I think I've got it now. My MK1 doesn't have MFA but does have that plug on the cluster (only missing the VSS (white / yellow) wire in my new CE1 loom). It doesn't have the speed sensor on the back of the cluster next to the speedo - it has an area which looks like it can be pushed out for it though so I'll either get a new cluster or the speed sensor from a new cluster and work out how to attach it.
    Here is a pic of the rear of my cluster:
    T6 is to the right of the printed circuit left of the speedo. Speed sensor tab just above this and to the right.
    I've also learnt that some MK1 Cabs and Sciroccos had cruise control with the controls on the end of the stalk which means I don't need to make up a custom panel - will just try to find on of these:
  12. rubjonny
    yup you got it poke out the blanking plate with a screwdriver and fit the sensor :)
    im not sure if the mk1/2 type button can be wired to mk4 cruise, I tried to figure it comparing the diagrams but it was a bit of a head scratcher! ideally I need both side by side so i can check what signals all the pins generate on the stalks as the diagrams are not clear
  13. scruffydubber Paid Member Paid Member
    Dubhampton
    Great thread rubjonny,
    Maybe I can add one small piece of info
    T10w - white or T10d - green 10 pin connector
    1 wht/red bin to vag-com port but unsure of what its for? works fine without!
    This wire has to be connected to 12v, ONLY when you want to flash the AGU ECU in the car. I believe it only applies to the AGU.
  14. rubjonny
    hmm! so if you put 12v into that pin, and have the can-bus wires on the diagnostics port you can map the ecu thru the port like a later dbw ecu? could you code out the immob this way as well?
  15. scruffydubber Paid Member Paid Member
    Dubhampton
    Yes I believe so. Although it only needs the K-line.
  16. benthejettaman Forum Member
    i have a 428 relay and not a 109 relay, can i change the 428 to a 109? if so then i can use a standard relay holder
  17. rubjonny
    yes the 109 is used in place of the 428, alternatively you could just leave the ecu relay alone and mount the waterproof box somewhere :)
    erreesse and benthejettaman like this.
  18. MUSHY 16V
    aberdeen
    if your looking to remove immobilizer have a look at vag commander
    this is what Alan and i used to get the skc to from my r32 ecu to code it his bora clocks
    it has a immo switch to turn the immobilizer off all together
    only conects to the ecu if you have a miss match in the immo for some reason
    like wise the super vag i have only works if the immo is matched
    you can use a dum usb lead with vag commander
  19. benthejettaman Forum Member
    i would but like it looking oem
  20. benthejettaman Forum Member
    ive stupidly cut the wires on my Coolant warning light control relay on my mk1 where do you connect pin 15 to?
