Pedal Box Master Cylinders
Discussion in 'Chassis' started by theboysmiffy, Nov 27, 2019.
  1. theboysmiffy
    theboysmiffy Forum Member
    Gateshead
    Hi all.
    Going to install HRP pedalbox/column in the Mk1 Rocco and will be running standard Gti brakes with DS2500 pads on the front.
    Can anyone tell me the correct master cylinder size for the front and rear and which brand does everyone use/recommend?
    Do people run remote reservoirs into the engine bay or is there enough room under the dash?
    Thanks for any help.
    Adam
  2. theboysmiffy
    Gateshead
  3. vw_singh Events Team Paid Member
    That should be about right although you'll need a bias valve for the rear. If the rear still locks up too easy then use a 0.7 rear.
  4. theboysmiffy
    Gateshead
    Thanks. Does the balance bar not do the job of the bias valve?
