Hi all, I’m new to this I have a mk4 golf pd 130 asz I can not get it to start it was fine until it was stood in m6 traffic for 4 hour it start running ruff it limped me home. So the morning after went to start it nothing just cranks over so changed lift pump still no start changed fuel filter nothing changed relay 109 nothing changed injector loom nothing changed crank sensor nothing changed tandem pump nothing it’s throw no codes on vagcom timing is ok what is wrong with it please someone help me
Take the tube from intercooler to inlet manifold off at manifold and see if the engine start, If so, check the turbo for damage ( as engine get little or no air )
Ok I will try this thank you for your quick reply. Last night it fired up off easy start but didn’t rev it’s like it’s getting staved off something
