Anyone have a pinout of a 9n3 polo quadlock plug? Im trying to find the CAN high and CAN low to connect my CAN-BUS adapter to. Either its not where it should be or Connects2 have sold me a duff adapter. Cheers Mat
is there not a wiring diagram on the headunit itself? oh and remember dont solder onto ur can-bus wires, twist the wire on and heat shrink
Note for anyone, Connects2 CAN-BUS adapters are cack. The 2 things i wanted mostly, Illumination and ignition dont work! Managed to get around them both, Wired the ignition up to the aerial power on the harness and works like it used to on the OEM radio. Have left the illumination off for now as its easy to change the brightness quickly and it goes into night mode on its own anyway. The speed pulse and reverse signal work. Pics soon!
