Pro Alloy Replacement Fuel Pump Housing
Discussion in 'Mk2' started by graham989, Dec 18, 2018.
  1. graham989 Paid Member Paid Member
    Lincolnshire
    Morning all,
    Has anyone got one of these;
    http://www.proalloy.co.uk/cgi-bin/sitewise.pl?act=det&pt=52_62_143&p=2901&id=proalloy
    Mine is buggered and been repaired a few times, looking at used ones, but they’re nearly as expensive as these.
    These look OEM which I like, as I’m trying to keep the look of the car original.
    Mines a 1986 K-jet EV, so I also wondered if I would need a new pump, as this says it’s for 16v’s (which apparently has a larger pump).
    Any thoughts, views, experience great fully received as always.
    the UK spec 8v kjet pump, housing, accumulator, etc all same as 16v so it'll all swap over :)
  3. graham989 Paid Member Paid Member
    Lincolnshire
    Cheers Jonny,
    Really appreciated.
    :thumbup:
  4. mikellloyd
    mikellloyd Paid Member Paid Member
    South London
    Hi guys,
    Resurrecting this as my car has sprung a leak from the pump housing (again).
    Same issue I’m replacing it, k-jet housings seem in short Supply these days. Anyone had a pro alloy one? They look good, pricey but if you get what you pay for that’s not the end of the world. Anyone used one before?
    cheers,
    mike
  5. Aaron16v New Member
    I've got one of these on my mine, fitted 2 years ago with new everything to go in it and I've had absolutely no problems from it whatsoever, plus these won't break apart when you need to change the filter like the plastic ones generally do in this day and age, well worth the investment IMO
  6. mikellloyd
    South London
    Thanks for that, good to have a vote of confidence. It’s a big buy but when 30 year old second hand ones seem to be half the price it actually makes the pro alloy seem reasonable
  7. graham989 Paid Member Paid Member
    Lincolnshire
    I bit the bullet and got one installed about 2 years ago.
    No issues with it, expensive, but when you look at really crappy ones going for silly money, I thought that as I was keeping the car forever it just made sense.
