He happened to someone so?. -COM Idle speed value on VAG shows me 650 -670. When you turn on the headlights begin to oscillate if they .Iar steering wheel drops to the engine dies. Otherwise the engine sounds good, shoot well, do not interrupt. The technician in charge of repair, still being repaired has made the following checks: -incarcare Battery Status - OK; The probe - EGR Okay; Catalyst - OK; Gasoline pump OK; OK throttle; (Replaced); MAP sensor - OK Introducing steam valve in the tank - OK Machine - OK Needle - OK Okay per cylinder Compressors Okay injectors; There is no error in the board; Parameters SGA -Comm read - I'm OK; Air Filter - fuel filter replaced Okay;
