Hi, I see eurowise in the states make mounts and driveshafts for the vr6, doesn't mention anything about the R32 lump though. Are they the same? Also is there an off the shelf manifold available? I see plenty for mk2's but nothing for a mk1 R32. Thanks
yes the mount kits should all swap over fine if you use the VR6/V5 gearbox, the front bracket may need a tweak depending on what you are supposed to do about that, the vr6 front bracket hits the r32 oil cooler iirc so needs a tweak as you say only thing is the vr6 conversion manifolds dont fit the r32 so need to buy/make one specific for mk1 -> r32
