Bringing an old friend back to life..
Discussion in 'Mk2' started by KeithMac, Jul 10, 2018.
  1. KeithMac Forum Junkie
    Kazakhstan
    Finally made enough space at home to be able to take the engine etc out and get my old lady back on the road!.
    Nice and easy weekend project and no need to rush to get it back together.
    Looking forward to taking time to do it right!
    Decided to go manual steering rack, are Meyle racks decent quality?.
    Toyotec likes this.
  2. Joehough
    Joehough Paid Member Paid Member
    Good luck, don't know about meyle racks, could you get your old one rebuilt?
  3. Joehough
    Sorry mis read that
  4. watercooled Forum Member
    Nelson,New Zealand
    someone on Vertex said they weren't that flash,then there were was a bunch of rapid relies with a big thumbs down ,however this site has so much BS who knows ? never used one myself.
    Good luck
  5. KeithMac Forum Junkie
    Kazakhstan
    Rack's arrived and doesn't look too bad!.
    Had a lucky escape, bought two 500kg screw lifts, got car 2 foot off floor then BANG!, lift failed.
    Looking at it they expected a soft 4mm roll pin to support half a ton, absoultey shocking!.
    I was going to get stands under as well but lucky it failed as it would have been an accident waiting to happen..
  6. m1keh Forum Member
    For the safety of everyone else who might buy those lifts I think you should be reporting that failure to ~ trading standards??
    Something rated to 500kg should be fit for purpose and be tested to at hold least 1.5 times the stated working load and designed with a factor of safety even greater than that.
    DN5 and KeithMac like this.
  7. KeithMac Forum Junkie
    Kazakhstan
    Might be an idea with trading standards, they are dangerous in their factory state.
    I had no choice but to rebuild them into a safe state to use, 12.9 bolts thoughout and drilled some 10mm holes for a decent bolt to hold them up if they did go again. Plus axle stands and wheels under car as well..
  8. DN5
    DN5 Paid Member Paid Member
    Doncaster
    Great idea to report to trading standards!
    KeithMac likes this.
  9. KeithMac Forum Junkie
    Kazakhstan
    Got plenty done this afternoon, another hour or so's work and engine/ subframe will be out!.
    Managed to separate the seized aluminium hubcentric spacers and brake disks with brute force and ignorance!.
    Can I drift the hub out of the bearing with a suitable drift or is it a press out job at work?. To be fair I need to press bearings out anyway..
    Need a new G60 timing belt, maybe go for a wide belt conversion?.
    I'm powder coating the Neuspeed ARB's but not sure what to do with the rose joints, might look into chemical rust removal?.
    Onwards and upwards as they say...
  10. watercooled Forum Member
    Nelson,New Zealand
    I would return these to the seller,not really suitable for your job besides,bet they are made in China like the collection of floor jacks I have that have failed usually just out of warranty.
    Buy a good low profile trolley jack and some axle stands,don't what to see anyone get hurt here ok,cheers.
  11. watercooled Forum Member
    Nelson,New Zealand
    Wow you are moving fast....whats the motor???,not a stock 1.8 for sure and the front brakes ???
  12. KeithMac Forum Junkie
    Kazakhstan
    It's the 1.8KR 16v with BBM front mount alternator G60 kit, Scirroco inlet manifold, BBM fuel rail. 16vG60.
    Can't remember where the bigger front brakes came from, they were 5 stud originally, possibly Passat or VR6 Golf?. Pagid fast road pads.
    It was a work in progress so will be taking my time to neaten it all up, may go back to stock fuel pressure regulator as well.
    Re-wire is also on the cards but debating wether to get it through its MOT first!.
  13. KeithMac Forum Junkie
    Kazakhstan
    I have a Clarke Racing Aluminium low profile Jack and 4 stands.
    The irony was I bought these jacks to make lifting it safer!. After spending 3 hours on them yesterday they are safe now just shocking how they came out of the factory.
    Going to invest in some threaded screw type axle stands as well.
    I don't like getting under a car on axle stands as I always think it's possible to topple over, but use them as secondary support (along with wheels under sills).
    Have sent the seller a message so see what they say, have left a review as Dangerous with pictures and will look into Trading Standards as well.
  14. KeithMac Forum Junkie
    Kazakhstan
    Just been in touch with Ebay Safety team, sent a load of pictures in the hope they will take them off ebay at least.
    Seller had offered 10% refund!, sent a message back it was about safety rather than money...
  15. KeithMac Forum Junkie
    Kazakhstan
    Juust ordered 8 cans of this for wishbones, subframe etc. Its zinc based for corrosion protection.
    See how it looks but may put a Wurth gloss finish coat over the top?.
  16. m1keh Forum Member
    I'd buy new ones - the bearing surface looks rusted so won't be long before they start knocking. Simply bearings or similar should have something the right size id guess.
  17. KeithMac Forum Junkie
    Kazakhstan
    Cheers, they are American made so will be imperial threads I would have though.
  18. KeithMac Forum Junkie
    Kazakhstan
    Cracked on with the spare gearbox at the weekend (puller stopped play!).
    Big thanks to BrokeVW.com and JonOlds for some very helpfull pointers!.
    20180723_121519.jpg 20180723_122402.jpg 20180723_140042.jpg 20180723_162629.jpg 20180723_164113.jpg 20180726_175544.jpg
  19. Jon Olds Forum Junkie
    Nice looking puller...ooh arrh missus...
    Jon
  20. KeithMac Forum Junkie
    Kazakhstan
    Managed to get a Peloquin Pelolock 80% kit for a good price as well so jobs a god one!.
    Need to find bearing numbers for the taper roller bearings next and order them though work (SKF NSK or Toyo)..
